查看: 11423|回复: 19
[求助] 怎么导入STDCELL的CDL
发表于 2014-6-20 09:31:00 | 显示全部楼层 |阅读模式
大家好!
我手头有standard cell的cadence symbol和cmos_sch view,但cmos_sch只有pin没有电路。
fab也提供了cdl文件,但我该如何把它导进去呢?
我在CDL IN页面填写了Reference Lib为analogLib,Device-Map file是自己写的,只有nfet和pfet。
请问大家是怎么做的?
发表于 2014-6-20 11:38:35 | 显示全部楼层
==>1. no connect line ?
     2. Reference Lib needs to have your process ex: XXX_018um
mpig
 楼主| 发表于 2014-6-20 15:23:17 | 显示全部楼层
回复 2# mpig09
    Hi mpig,
1. What is connect line in map file? Can you provide an example?
2. May be the process is incomplete, it's not provided by foundry and from elsewhere. I just use it for study purpose.
发表于 2014-6-22 17:42:49 | 显示全部楼层
Hi abcn101:
==>not in map file
       can you provide the schematic when your cdlin, and check the mos has connection line or not?
==>does the schematic has mos and the mos characteristic (w/l, type) is the same with your cdl?
mpig
发表于 2014-6-22 18:11:35 | 显示全部楼层
关注这个问题- -我最近也要搞
 楼主| 发表于 2014-6-23 09:25:51 | 显示全部楼层
回复 4# mpig09
    It does have connect line and mos, the size is correct too.
    But some input has become output and output has become input, in schematic view.
   For example A is input in symbol but became output in sch,
   Y is output in symbol but became input in sch.
发表于 2014-6-23 14:09:05 | 显示全部楼层
Hi abcn101:
==>Sorry, I don't know how to solve this problem.
      I solve it manually.
Hope someone know how to solve it.
mpig
发表于 2014-7-3 15:25:21 | 显示全部楼层
回复 1# abcn101
   为什么Device Map File中要写nfet和pfet?是因为你用的是analogLib吗??
如果我把reference Lib设定为PDK,那应该怎么办??
 楼主| 发表于 2014-7-4 09:06:34 | 显示全部楼层
回复 8# Rucas
    我也就看到网上怎么说的,
PDK的情况就不清楚了
发表于 2014-7-4 09:48:23 | 显示全部楼层
回复 9# abcn101
   OK 3Q!
GMT+8, 2025-12-14 12:33 , Processed in 0.021946 second(s), 6 queries , Gzip On, Redis On.
