查看: 7089|回复: 6
[求助] 关于biquad
发表于 2014-6-16 23:09:33 | 显示全部楼层 |阅读模式
biquad是双二阶,这种结构的双二是什么意思?传输函数分子分母都是二阶的?
Biquad Switched Capacitor Filter呢?
找到这样的一个相关内容:MAX261是美国MAXIM公司推出的CMOS双二阶通用开关电容有源滤波器,其内部含有两个二阶滤波单元。
so biquad的意思就是两个二阶的意思么?美信的biquad filter有一个经典结构,难不成这个biquad就只是指这个(种)特定结构么?
想不明白了啊,求大神指教一下
 楼主| 发表于 2014-6-16 23:13:26 | 显示全部楼层
google也上不去,坑爹,度娘啥都不知道
发表于 2014-6-17 03:49:36 | 显示全部楼层
biquad is also called bi-linear, basically in the frequency response, the denominator is second order while and numerator can be as high as 2nd order.
 楼主| 发表于 2014-6-17 10:40:10 | 显示全部楼层
回复 3# icdane
thaks,
发表于 2014-11-27 09:58:42 | 显示全部楼层
In signal processing, a digital biquad filter is a second-order recursive linear filter, containing two poles and two zeros. "Biquad" is an abbreviation of "biquadratic", which refers to the fact that in the Z domain, its transfer function is the ratio of two quadratic functions
发表于 2017-9-25 21:04:57 | 显示全部楼层
thanks for your sharing
发表于 2021-6-10 15:56:19 | 显示全部楼层
谢谢
GMT+8, 2025-12-25 23:38 , Processed in 0.021841 second(s), 5 queries , Gzip On, Redis On.
