查看: 6153|回复: 4
[求助] 新手求助后访失败
发表于 2014-6-6 01:35:08 | 显示全部楼层 |阅读模式
报错如下:
ERROR: Netlister : terminal 'in' found in cell 'inv', view 'symbol' does not exist in cell 'inv' view 'calibre'.
ERROR: Netlister : terminal 'out' found in cell 'inv', view 'symbol' does not exist in cell 'inv' view 'calibre'.
Netlist Warning: Number of terms specified is more than the actual number of
  terms in cell-view "Joy" "inv" "calibre"
Netlist Warning: Mismatch was found between the terminals in the cellView and
  those on the pin order property on the schematic, or on the termOrder
  property on the CDF. The internal default order is being used. Please
  eliminate the mismatch if any of the above properties must be used for
  netlisting.
ERROR: Netlister : terminal 'in' of instance 'I0', in cell 'inv_test', view 'schematic' : cannot be found in the switched master of the instance.
ERROR: Netlister : terminal 'out' of instance 'I0', in cell 'inv_test', view 'schematic' : cannot be found in the switched master of the instance.
End netlisting Jun  5 10:19:22 2014
ERROR (OSSHNL): Error(s) found during netlisting. The netlist may be corrupt
  or may not be produced at all.
To generate correct netlist, fix the errors and re-netlist.
      ...unsuccessful.
刚接触IC,什么 都 不懂 希望前辈们详解。谢谢啦……
发表于 2014-6-17 14:36:50 | 显示全部楼层
把电路图和版图都贴上来看看啊。话说,你的DRC和LVS是PASS的咩?
发表于 2015-5-4 17:31:59 | 显示全部楼层
楼主,这个问题你解决了没有啊?
发表于 2021-9-29 14:59:33 | 显示全部楼层
我也遇到这个问题了。解决方法:
将模块的pin全部换成大写“IN”"OUT"
发表于 2021-9-29 15:05:15 | 显示全部楼层
LVS是否区分大小写的问题?
GMT+8, 2025-12-23 03:15 , Processed in 0.021539 second(s), 8 queries , Gzip On, Redis On.
