查看: 2968|回复: 3
[活动] 每日一奖----20140528
发表于 2014-5-28 10:55:54 | 显示全部楼层 |阅读模式
悬赏200资产未解决
Q17. What is SDC constraint file contains?
发表于 2014-5-28 11:09:24 | 显示全部楼层
1.clock period  &wave form
2.false path
3.input output delay
4.input drive,output load
5.uncertainty
6.disable timing
发表于 2014-5-28 12:30:25 | 显示全部楼层
Agree with "zzvbk".
Also, max_transition, max/min delay, multicycle path, etc. are included. All the timing constraints and specification of the design are included in the sdc files.
发表于 2014-5-28 14:11:56 | 显示全部楼层
SDC:Full form of SDC: Synopsys Design Constraints
SDC is a format used to specify design intent, which is including timing, power and area constraints for a design. SDC is tcl based. DC ICC and Primetime use SDC file.
GMT+8, 2025-12-21 21:26 , Processed in 0.019258 second(s), 6 queries , Gzip On, Redis On.
