Allows Visual Studio 2012/2013 packages to be downloaded to an offline cache location before importing them into Microsoft Help Viewer 2.0/2.1.
Quick Guide
1- Select the version of Visual Studio to download the help for-
2- Select your language from the drop down list
3- Press "Load Books" to retrieve the list of available books. Books that are already in the cache (partially or fully) will automatically be checked. Note that because packages are shared between different books, you may get extra items checked automatically.
4- Check (or uncheck) book that you want to download. The "Download Size" and "Num Downloads" columns indicate an approximate amount of data that needs to be downloaded for the book based on what is already in the cache.
5- Press "Download" to start downloading the requested books. Packages for books no longer selected will be deleted at this point.
6- When the download is complete, import the new books into "Microsoft Help Viewer" using the "Manage Content" tab. |
