查看: 2832|回复: 1
[求助] 求助,ADS与Mentor动态链接的问题
发表于 2014-5-22 08:53:02 | 显示全部楼层 |阅读模式
我需要将ADS与mentor动态链接,按照帮助文件,Installing the Dynamic Access for Mentor Design Kit,但是发现找不到 MentorADSMessaging.dll.
按照帮助文件的提示:The Mentor installation process typically adds the path to this file to the system path, making it available to ADS. If the ADS path does not include the Mentor installation folders, you must add them before Dynamic Access for Mentor will operate properly. 请教,我怎样添加ADS Path,让ADS 能找到Mentor安装路径?
发表于 2014-5-27 21:00:40 | 显示全部楼层
估计是搞环境变量设置
path。。。。。。。
GMT+8, 2025-9-14 03:17 , Processed in 0.015890 second(s), 5 queries , Gzip On, Redis On.
