查看: 3517|回复: 2
[求助] 求大神帮忙看看,为什么我综合完 cell delay都是0?新手求助
发表于 2014-5-19 21:02:07 | 显示全部楼层 |阅读模式
综合后发现cell delay都是零,很奇怪:
1、
Report : timing
        -path full_clock
        -delay max
        -nworst 10
        -max_paths 10
Design : multiplier
Version: B-2008.09
Date   : Mon May 19 20:47:02 2014
Operating Conditions: NCCOM   Library: tpz973gtc
Wire Load Model Mode: top
  Startpoint: dataout_reg[0]
              (rising edge-triggered flip-flop clocked by clk)
  Endpoint: dataout[0] (output port clocked by clk)
  Path Group: clk
  Path Type: max
  Des/Clust/Port     Wire Load Model       Library
  multiplier         TSMC128K_Conservative tpz973gtc
  Point                                    Incr       Path
  clock clk (rise edge)                    0.00       0.00
  clock network delay (ideal)              0.20       0.20
  dataout_reg[0]/CK (DFFTRX1)              0.00       0.20 r
  dataout_reg[0]/Q (DFFTRX1)               0.00       0.20 r
6/Y (CLKBUFX8)                          0.00       0.20 r
  dataout[0] (out)                         0.00       0.20 r
  data arrival time                                   0.20
  clock clk (rise edge)                    5.00       5.00
  clock network delay (ideal)              0.20       5.20
  clock uncertainty                       -0.01       5.19
  output external delay                   -0.50       4.69
  data required time                                  4.69
  data arrival time                                  -0.20
  slack (MET)                                         4.49
2、
  Startpoint: reset (input port)
  Endpoint: dataout_reg[9]
  Path Group: clk
  Path Type: min
  Point                                    Incr       Path
  clock (input port clock) (rise edge)     0.00       0.00
  clock network delay (ideal)              0.00       0.00
  input external delay                     0.00       0.00 f
  reset (in)                               0.00       0.00 f
  U3/Y (CLKINVX1)                          0.00       0.00 r
  dataout_reg[9]/U2/Y (AND2X1)             0.00       0.00 r
  dataout_reg[9]/D (DFFHQX1)               0.00       0.00 r
  data arrival time                                   0.00
  clock network delay (ideal)              0.10       0.10
  clock uncertainty                        0.01       0.11
  dataout_reg[9]/CK (DFFHQX1)              0.00       0.11 r
  library hold time                        0.00       0.11
  data required time                                  0.11
  slack (VIOLATED)                                   -0.11
我再贴下我用的2个库啊:typical.lib:
cell (ADDFHX2) {
  cell_footprint : addfh;
  area : 113.0976;
  pin(A) {
    direction : input;
    capacitance : 0.01159;
  pin(B) {
    direction : input;
    capacitance : 0.02595;
  pin(CI) {
    direction : input;
    capacitance : 0.00805;
  pin(S) {
    direction : output;
    capacitance : 0.0;
    function : "(A ^ B ^ CI)";
    internal_power() {
      related_pin : "A";
      when : "!B & !CI";
      rise_power(energy_template_7x7) {
        index_1 ("0.0300, 0.1000, 0.4000, 0.9000, 1.5000, 2.2000, 3.0000");
        index_2 ("0.00070, 0.04200, 0.07700, 0.16800, 0.29400, 0.46200, 0.62300");
        values ( \
          "0.1774, 0.1829, 0.1818, 0.1792, 0.1754, 0.1701, 0.1645", \
          "0.1753, 0.1812, 0.1801, 0.1774, 0.1734, 0.1681, 0.1635", \
          "0.1869, 0.1919, 0.1908, 0.1882, 0.1844, 0.1791, 0.1735", \
          "0.2259, 0.2239, 0.2221, 0.2188, 0.2144, 0.2091, 0.2045", \
          "0.2712, 0.2700, 0.2676, 0.2651, 0.2614, 0.2561, 0.2505", \
          "0.3256, 0.3251, 0.3252, 0.3202, 0.3164, 0.3111, 0.3055", \
          "0.3900, 0.3899, 0.3901, 0.3881, 0.3814, 0.3761, 0.3705");
查找表看的,cell delay都是有的啊,求大神指点一下!!!感激不尽
 楼主| 发表于 2014-5-19 21:14:29 | 显示全部楼层
谁来帮我回答一下啊?cell delay都是零,hold没有办法满足啊`
发表于 2014-5-20 13:48:29 | 显示全部楼层
可否用report_delay_calculation -from -to 看得详细一点
GMT+8, 2025-12-11 07:02 , Processed in 0.020240 second(s), 6 queries , Gzip On, Redis On.
