查看: 13511|回复: 17
[原创] Lumerical 2013b All product Crack
发表于 2014-5-13 20:14:54 | 显示全部楼层 |阅读模式
LumericL 2013b All product Crack for
WINDOWS VERSION
For both 32 AND 64 bit
First download Lumerical 2013b from this here.
http://bbs.eetop.cn/viewthread.php?tid=445511&highlight=lumerical
Then;
- Unpack Lumerical_FlexLM-1.1.6.zip and install new FlexLM License Server (if not installed)
  default install program directory: "c: \ Program Files (x86) \ Lumerical \ Lumerical-FlexLM \"
- Unpack lumerical.FlexLM.cmd a sfk166.exe from this archive to program directory,
- Run lumerical.FlexLM.cmd in program directory with Administrator privileges,
  see fig. "lumerical.FlexLM.patch.OK.png" from this archive,
- Unpack license-server.lic from this archive to temporary dir "C: \ Temp \ lumerical \"
- Open FlexNet Publisher http://localhost:8095
- From temporary dir import license file: "license-server.lic"
- Configure LUMERICL vendor daemon, only change default port: 5286 etc.
- Run LUMERICL vendor daemon
- Check correct funkcionality see fig from this archive: "lumerical.FlexLM.server.OK.png".
- If license server is OK, continue with install all or any product from zip archives:
DEVICE-3.0.2.zip
FDTD_Solutions-8.6.2.zip
INTERCONNECT-3.0.2.zip
MODE_Solutions-6.5.2.zip
- Run ... installer.exe
  Options: uncheck "Install Sentinel HASP drives (required for hardware key)"
- Next, next, close,
- Click OK,
- Run another ... install.exe
- Etc.
[Attach] 581981 [/ attach]
Lumerical_all_products_2013b_(x86-x64)_cr.rar
880.96 KB, 下载次数: 362 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2014-5-15 03:00:13 | 显示全部楼层
I'm realy need these software and crack of them. thanks alot
发表于 2014-5-15 21:26:39 | 显示全部楼层
下来看看
发表于 2014-5-15 21:28:14 | 显示全部楼层
下来看看
 楼主| 发表于 2014-5-16 02:32:05 | 显示全部楼层
 楼主| 发表于 2014-5-16 02:37:03 | 显示全部楼层
I can upload each one of these software on EETOP but it takes time.
If you want it, just tell me.
发表于 2014-5-22 17:48:59 | 显示全部楼层
这个东东好难找啊,多谢楼主
发表于 2014-9-10 19:58:55 | 显示全部楼层
回复 1# nova6
some problems can be settled
发表于 2014-9-14 05:04:42 | 显示全部楼层
Thanks, I really need it. Take a look at the material modeling there which is very good.
发表于 2014-11-6 01:31:02 | 显示全部楼层
可以用么,这个?
GMT+8, 2025-12-27 11:07 , Processed in 0.019655 second(s), 6 queries , Gzip On, Redis On.
