查看: 2078|回复: 0
[求助] 关于IC610安装的求助 江湖救急
发表于 2014-5-8 12:28:54 | 显示全部楼层 |阅读模式
按照教程做  结果遇到了这个   求助各位大神
Type the path to InstallScape installation directory [ (q to quit)]: /home/eda/installscape
InstallScape installation directory: /home/eda/installscape
Extracting InstallScape version 03.40.p06
for platform lnx86 in /home/eda/installscape
Starting up InstallScape in GUI mode
DISPLAY environment variable is set to :0.0
If you do not see the InstallScape console
window or the it seems to be hanging then kill this
process.
Set your DISPLAY environment variable to a proper
value and manually start InstallScape by typing:
/home/eda/installscape/iscape/bin/iscape.sh /home/janber/ic610/CDROM1:::/home/eda/ic610
Initializing InstallScape using JVM at /home/eda/installscape/iscape/runtime/LNX86/bin/java. This might take some time...
/home/eda/installscape/iscape/bin/iscape.sh: /home/eda/installscape/iscape/runtime/LNX86/bin/java: /lib/ld-linux.so.2: bad ELF interpreter: No such file or directory
/home/eda/installscape/iscape/bin/iscape.sh: line 209: /home/eda/installscape/iscape/runtime/LNX86/bin/java: Success
GMT+8, 2025-12-27 13:07 , Processed in 0.015324 second(s), 7 queries , Gzip On, Redis On.
