查看: 8024|回复: 23
Good IEEE papper on frequency compensation
发表于 2007-3-19 06:54:18 | 显示全部楼层 |阅读模式
Single Miller Capacitor Frequency Compensation Technique for Low-Power Multistage Amplifiers
abbr_434b7b8dcc6aa42819543f869fe5d2bd.pdf
1.29 MB, 下载次数: 98 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-3-19 14:22:58 | 显示全部楼层
seeing!Thanks!
发表于 2007-3-19 19:58:40 | 显示全部楼层
xiexie
发表于 2007-3-19 23:29:58 | 显示全部楼层
发表于 2007-3-20 10:15:35 | 显示全部楼层
IEEE JOURNAL OF SOLID-STATE CIRCUITS, VOL. 40, NO. 3, MARCH 2005
发表于 2007-3-20 10:19:58 | 显示全部楼层
REFERENCES
REFERENCES
[1] E. Sánchez-Sinencio and A. G. Andreou, Low-Voltage Low-Power Integrated
Circuits and Systems. New York: IEEE Press, 1999.
[2] G. A. Rincón-Mora, “Active capacitor multiplier in Miller-compensated
circuits,” IEEE J. Solid-State Circuits, vol. 35, no. 1, pp. 26–32, Jan.
2000.
[3] G. A. Rincón-Mora and P. E. Allen, “A low-voltage, low quiescent current,
low drop-out regulator,” IEEE J. Solid-State Circuits, vol. 33, no.
1, pp. 36–44, Jan. 1998.
[4] R. G. H. Eschauzier, L. P. T. Kerklaan, and J. H. Huijsing, “A 100-MHz
100-dB operational amplifier with multipath nested Miller compensation
structure,” IEEE J. Solid-State Circuits, vol. 27, no. 12, pp. 1709–1717,
Dec. 1992.
[5] F. You, S. H. K. Embabi, and E. Sánchez-Sinencio, “Multistage amplifier
topologies with nested G -C compensation,” IEEE J. Solid-State
Circuits, vol. 32, no. 12, pp. 2000–2011, Dec. 1997.
[6] K. N. Leung and P. K. T. Mok, “Nested Miller compensation in low
power CMOS design,” IEEE Trans. Circuits Sys. II, vol. 48, no. 4, pp.
388–394, Apr. 2001
发表于 2007-3-20 10:23:01 | 显示全部楼层
CONCLUSION
CONCLUSION
Two compensation topologies for low-power multistage amplifiers
specifically for large capacitive loads are introduced,
SMC and SMFFC. It is shown that with only a small compensation
capacitor, the area of the amplifier is reduced significantly,
the gain-bandwidth product is improved, and the stability condition
is established. The separate pole approach is used to perform
the analysis for large capacitive loads. A feedforward path
is added to the SMFFC amplifier to further improve the GBW
and to reduce the silicon area. Based on a comprehensive comparison
of the proposed amplifiers against other reported structures
with large capacitive loads, the proposed compensation
techniques demonstrate superior performance.
发表于 2007-3-20 11:01:47 | 显示全部楼层
单一米勒电容补偿,在运放中很常见
头像被屏蔽
发表于 2007-3-20 17:36:35 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2007-7-13 15:45:09 | 显示全部楼层
下载中,希望有所帮助,谢谢!
GMT+8, 2025-12-22 05:46 , Processed in 0.025720 second(s), 6 queries , Gzip On, Redis On.
