查看: 1750|回复: 1
[招聘] 【上海】Marvell诚招Firmware engineer
发表于 2014-4-25 14:32:15 | 显示全部楼层 |阅读模式
JobTitle:
Firmware engineer
JobDescription:
This is an entry level, firmwareengineering oriented system engineer position. The engineer will be part of thevertical system engineering team composed with hardware engineering, softwareengineering, firmware engineering, FPGA design engineering, signal integrityengineering, and others. The IC products to work with include EthernetPHY/NIC/Switch/SoC, high speed SerDes based PHYs, DTV front end components, PLCPHYs, and so on. System engineering team is responsible for many post siliconengineering efforts like product validation, platform development, collateraldevelopment, technical support and so on.
JobResponsibilities:
- Boot Code Development.
- BSP Development.
- API Driver Suite Development.
- Protocol Stack Firmware Development.
- Application Level Firmware Development.
- Technical Support to Customers.
JobQualification:
- BS/MS in EE/CE/CS.
- Must have good program skill.
- Must be familiar with embedded system.
- Must have good knowledge with computersystem and data network system.
- Must be willing to work in amulti-tasking, fast pace, team oriented working environment.
- Must be able to quickly absorb differentkinds of knowledge and apply them in the works.
- Working experience on firmware/softwaredevelopment are preferred.
- Familiarity with Ethernet and networkprotocols are some pluses.
If you areinterested in exploring a job opportunity with Marvell, please send me a copyof your bilingual resume to: al-china-hr@marvell.com EmailSubject: 姓名_学历_学校_工作年限_应聘岗位_意向城市; 比如: 张三_硕士_东南大学_3yrs_Platform_南京
发表于 2014-4-29 10:04:03 | 显示全部楼层
为什么北京的职位那么少啊
GMT+8, 2025-12-25 21:02 , Processed in 0.017814 second(s), 5 queries , Gzip On, Redis On.
