查看: 14837|回复: 7
[求助] Xilinx K7系列中OSERDES的问题
发表于 2014-4-24 17:42:23 | 显示全部楼层 |阅读模式
我的ISE版本是14.6,设计了一个简单的OSERDES程序,用来产生DAC数据时钟,思路如下:
100MHz钟-->MMCM-->(CLK=500MHz钟,CLK_DIV=250MHz钟)-->OSERDES(DDR,4:1,并行数据=4'b1010)-->500MHz数据时钟输出
用ISIM做功能仿真正确,但implement后的时序仿真输出数据时钟始终不变(恒定为0),不知道到底怎么回事?麻烦高手指点迷津,谢谢!源码如下
`timescale 1ns/1ps
module TOP_DESIGN
      input  clk_in,
      input  reset_pll,
      input  reset_serdes,
      output mmcm_lock,
      output CLK_TO_PINS_P,
      output CLK_TO_PINS_N
wire        clkfbout;
wire        clkout0;
wire        clkout1;
wire        clkfbout_buf;
wire        clkin1;
wire        highspeed_clk;
wire        lowspeed_clk;
reg         IO_RESET;
reg  [7:0]  rst_dly;
wire        oserdes_out;
MMCME2_ADV #
        .BANDWIDTH            ("OPTIMIZED"),
        .CLKOUT4_CASCADE      ("FALSE"),
        .COMPENSATION         ("ZHOLD"),
        .STARTUP_WAIT         ("FALSE"),
        .DIVCLK_DIVIDE        (1),
        .CLKFBOUT_MULT_F      (10.000),
        .CLKFBOUT_PHASE       (0.000),
        .CLKFBOUT_USE_FINE_PS ("FALSE"),
        .CLKOUT0_DIVIDE_F     (2.000),
        .CLKOUT0_PHASE        (0.000),
        .CLKOUT0_DUTY_CYCLE   (0.500),
        .CLKOUT0_USE_FINE_PS  ("FALSE"),
        .CLKOUT1_DIVIDE       (4.000),
        .CLKOUT1_PHASE        (0.000),
        .CLKOUT1_DUTY_CYCLE   (0.500),
        .CLKOUT1_USE_FINE_PS  ("FALSE"),
        .CLKIN1_PERIOD        (10.0),
        .REF_JITTER1          (0.010)
U1_MMCM
     (  // Output clocks
.CLKFBOUT            (clkfbout),
        .CLKFBOUTB           (),
        .CLKOUT0             (clkout0),
        .CLKOUT0B            (),
        .CLKOUT1             (clkout1),
        .CLKOUT1B            (),
        .CLKOUT2             (),
        .CLKOUT2B            (),
        .CLKOUT3             (),
        .CLKOUT3B            (),
        .CLKOUT4             (),
        .CLKOUT5             (),
        .CLKOUT6             (),
        // Input clock control
        .CLKFBIN             (clkfbout_buf),
        .CLKIN1              (clkin1),
        .CLKIN2              (1'b0),
        // Tied to always select the primary input clock
        .CLKINSEL            (1'b1),
        // Ports for dynamic reconfiguration
        .DADDR               (7'h0),
        .DCLK                (1'b0),
        .DEN                 (1'b0),
        .DI                  (16'h0),
        .DO                  (),
        .DRDY                (),
        .DWE                 (1'b0),
        // Ports for dynamic phase shift
        .PSCLK               (1'b0),
        .PSEN                (1'b0),
        .PSINCDEC            (1'b0),
        .PSDONE              (),
        // Other control and status signals
        .LOCKED              (mmcm_lock),
        .CLKINSTOPPED        (),
        .CLKFBSTOPPED        (),
        .PWRDWN              (1'b0),
        .RST                 (reset_pll)
BUFG U2_BUFG
        .O (clkfbout_buf),
        .I (clkfbout)
BUFG U3_BUFG
        .O (highspeed_clk),
        .I (clkout0)
BUFG U4_BUFG
        .O (lowspeed_clk),
        .I (clkout1)
IBUFG U5_BUFG
     (  .I (clk_in),
        .O (clkin1)
OSERDESE2
         .DATA_RATE_OQ   ("DDR"),
         .DATA_RATE_TQ   ("SDR"),
         .DATA_WIDTH     (4),
         .TRISTATE_WIDTH (1),
         .SERDES_MODE    ("MASTER")
U6_SERDES
         .D1             (1'b1),
         .D2             (1'b0),
         .D3             (1'b1),
         .D4             (1'b0),
         .D5             (1'b1),
         .D6             (1'b0),
         .D7             (1'b1),
         .D8             (1'b0),
         .T1             (1'b0),
         .T2             (1'b0),
         .T3             (1'b0),
         .T4             (1'b0),
         .SHIFTIN1       (1'b0),
         .SHIFTIN2       (1'b0),
         .SHIFTOUT1      (),
         .SHIFTOUT2      (),
         .OCE            (rst_dly[4]),
         .CLK            (highspeed_clk),
         .CLKDIV         (lowspeed_clk),
         .OQ             (oserdes_out),
         .TQ             (),
         .OFB            (),
         .TFB            (),
         .TBYTEIN        (1'b0),
         .TBYTEOUT       (),
         .TCE            (1'b0),
         .RST            (IO_RESET)
OBUFDS
      #(.IOSTANDARD ("LVDS"))
obufds_inst
       (.O          (CLK_TO_PINS_P),
        .OB         (CLK_TO_PINS_N),
        .I          (oserdes_out)
always @ (posedge lowspeed_clk or posedge reset_serdes)
begin
    if(reset_serdes)
       begin
   IO_RESET <= 1'b1;
rst_dly  <= 8'b0000_0000;
end
    else
       begin
   IO_RESET <= 1'b0;
rst_dly[7:1] <= rst_dly[6:0];
rst_dly[0] <= 1'b1;
end
end
endmodule
 楼主| 发表于 2014-4-24 17:43:53 | 显示全部楼层
器件是XC7K325T-2FFG900
 楼主| 发表于 2014-4-24 18:28:37 | 显示全部楼层
再附上仿真用文件
`timescale
1 ns / 1 ps
module TOP_SIM();
localparam CLK100_PERIOD  = 10;   //in nSec
reg         clk_in;
reg         reset_pll;
reg         reset_serdes;
wire        mmcm_lock;
wire        CLK_TO_PINS_P;
wire        CLK_TO_PINS_N;
TOP_DESIGN
  SIM (
           .clk_in        (clk_in),
   .reset_pll     (reset_pll),
   .reset_serdes  (reset_serdes),
   .mmcm_lock     (mmcm_lock),
           .CLK_TO_PINS_P (CLK_TO_PINS_P),
   .CLK_TO_PINS_N (CLK_TO_PINS_N)
// Stimulation Generation
initial
   begin
      reset_pll = 1'b1;
      #200
      reset_pll = 1'b0;
   end
initial
   begin
      reset_serdes = 1'b1;
      #1200
      reset_serdes = 1'b0;
   end
// Clock Generation
initial
      clk_in = 1'b0;
always #(CLK100_PERIOD/2.0) clk_in = ~clk_in;
endmodule
发表于 2014-4-25 11:23:23 | 显示全部楼层
你把数据接出来看看 数据正确否? 很可能模块都没有工作。
发表于 2014-5-19 10:56:09 | 显示全部楼层
回复 1# hansonsi
你好,我也在使用K7,有个问题请教下,MMCME2_ADV是原语还是模块或者是IP啊?
发表于 2016-3-8 13:45:41 | 显示全部楼层
回复 5# nklc2009
   同问啊,这个MMCME2_ADV 是个啥,官网上下下来一个近4k行代码的这个module。都不知道他从哪里来的,干啥用的。
发表于 2016-7-28 13:44:16 | 显示全部楼层
没用过oserderse,学习下
发表于 2017-1-24 20:49:19 | 显示全部楼层
谢谢分享
GMT+8, 2025-12-27 06:39 , Processed in 0.017589 second(s), 3 queries , Gzip On, Redis On.
