查看: 2556|回复: 0
[求助] 请教仿真adc动态参数的matlab代码问题 懂的请来指点一下
发表于 2014-4-23 17:19:10 | 显示全部楼层 |阅读模式
各位:       最近在研究仿真adc动态参数的matlab代码,其中一段如下所示:
%Find harmonic frequencies and power components in the FFT spectrum
%For this procedure to work, ensure the folded back high order harmonics do not overlap
%with DC or signal or lower order harmonics , so it should be modified according to the actual condition
for har_num=1:10
    tone=rem((har_num*(fin-1)+1)/numpt,1); %Input tones greater than fSAMPLE are aliased back into the spectrum
    if tone>0.5
        tone=1-tone; %Input tones greater than 0.5*Fsample (after aliasing) are reflected
    end
其作用应该是:高频的谐波分量会混叠到低频上,应该找出并保证其不会影响低频信号。但是该语句是怎样做到的?
fin是输入信号在功率谱中的位置(2932),numpt是采样点数(8192)
期待您的回复!
GMT+8, 2025-12-28 19:49 , Processed in 0.021128 second(s), 5 queries , Gzip On, Redis On.
