查看: 2391|回复: 1
[求助] MODELSIM编程仿真遇到问题
发表于 2014-4-22 19:15:39 | 显示全部楼层 |阅读模式
有程序如下:要达到的目的是,当CLR为0时,输出为0,pc为0;当clr为1,ldpc为1时,输出为输入值,pc也为输入值,当clr为1,ldpc和load都为0时,pc加1,输出为pc,其他情况pc值不变,但现在仿真出来的波各种混乱,求哪位大神帮帮忙LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY PC IS
  PORT(INPC:IN STD_LOGIC_VECTOR(7 DOWNTO 0);
  CLR, LOAD, LDPC: IN STD_LOGIC;
  OUTPC:OUT STD_LOGIC_VECTOR(7 DOWNTO 0));
END ENTITY;
ARCHITECTURE PC OF PC IS
  SIGNAL PC: STD_LOGIC_VECTOR(7 DOWNTO 0);
  BEGIN
    PROCESS(CLR, LOAD, LDPC)
      BEGIN
        IF(CLR='0') THEN
          PC<=(OTHERS=>'0');
          OUTPC<=PC;
        ELSIF(LDPC='1') THEN
            PC<=INPC;
            OUTPC<=PC;
        ELSIF(LOAD='0' and LDPC='0') THEN
            PC<=PC+1;
            OUTPC<=PC;
         else PC<=PC;   OUTPC<=PC;
          END IF;
        ----END IF;
       ---=- OUTPC<=PC;
      END PROCESS;
    END PC;
 楼主| 发表于 2014-4-22 19:54:00 | 显示全部楼层
自己顶
GMT+8, 2025-11-25 21:09 , Processed in 0.015629 second(s), 6 queries , Gzip On, Redis On.
