查看: 2077|回复: 0
[招聘] NO.163-Sr Application Firmware Engineer/Manager(Shanghai)
发表于 2014-4-15 16:15:46 | 显示全部楼层 |阅读模式
Job Requirements:
1.    Build a world-class application team from scratch to support products in the new 32-bit Microcontroller Product Families.
2.    To innovate and clearly specify solutions to complex firmware / software problems.
3.    Developing and writing Data Sheets, Application Notes, Technical Briefs and Articles.
4.    Designing and developing software drivers, libraries and applications in support of new 32 bit controller product
5.    Developing and presenting technical training to customers, FAEs and field sales
6.    Assist large account design activities, working directly with customers and field support teams
7.    Manage and coordinate multiple projects that run simultaneously.
Qualifications
1.    MS Degree in Electrical Engineering and/or Computer Science and 6+ years of knowledge and experience in embedded system product development or semiconductor applications engineering.
2.    Deep familiarity with compiler tool chains and C language is required
3.    Must have experience with programming in embedded assembly and C programming languages.
4.    Must have good understanding of software development processes. Prior experience with motor control design is a plus.
5.    ARM Cortex knowledge and experience with RTOS is preferred.
6.    Must have digital circuit design and debugging experience.  Some analog experience is preferred.
7.    Extensive knowledge/experience in system hardware design required- power management, clock/reset, memory/storage management, various inter-chip communication interface/protocol/timing and firmware development.
8.    Familiarity with microprocessor/ microcontroller architectures is required.
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
“KT人才”微信也可查询职位啦!打开手机微信,搜号码“KTHR_COM”或查找微信公众帐号“KT人才”即可添加,欢迎大家关注!(关注成功后输入”KT“即可查询职位!)
GMT+8, 2025-12-26 10:42 , Processed in 0.017241 second(s), 6 queries , Gzip On, Redis On.
