查看: 2926|回复: 3
[求助] JLINK can't find ARM9 core
发表于 2014-4-14 09:59:06 | 显示全部楼层 |阅读模式
如果ARM9的指令总线挂死,会影响JLINK识别ARM9内核吗?
发表于 2014-4-17 11:18:36 | 显示全部楼层
经常出现can't find CPU core的情况 但都不是这个原因
发表于 2014-4-18 01:59:53 | 显示全部楼层
attach scope to JTAG signals, make sure they are happening
make sure clock applied to CPU using scope
make sure pinout and pcb are correct for power
confirm jtag probe is working or not on different board
etc
发表于 2016-8-18 17:57:15 | 显示全部楼层
should no't affect the detection of arm9 id,it's not touching instruction bus&data bus access arm9 id .
if can't detect the id,plz check the right ot jtag path.
GMT+8, 2025-12-30 00:12 , Processed in 0.017254 second(s), 6 queries , Gzip On, Redis On.
