宏单元flash里面有一对电源地VPP VNN在连接电源地的时候,pad和宏单元的电源地没有连起来。然后就命令连接,出现了错误。
derive_pg_connection -power_net VPP -power_pin VPP -ground_net VNN -ground_pin VNN -cells fzu8051_top_inst/FLASH_32KB
begin derive_pg_connection...
Error: Net VPP is not a power net. (MWUI-714)
derive pg failed
connect_net VPP [get_pins fzu8051_top_inst/FLASH_32KB/VPP]
Error: Objects 'VPP' and 'VPP' are at different levels in the design hierarchy. Nets can be connected only to pins and ports at the same hierarchical level. (UIED-37)
connect_net VPP [get_pins io_pad_inst/VPP_PAD/PADR1]
Error: Objects 'VPP' and 'PADR1' are at different levels in the design hierarchy. Nets can be connected only to pins and ports at the same hierarchical level.
还有就是我在例化pad的时候,pad上面有两个pin,P是inout PADR1是out的,我这样连接应该是对的吧?
PANALOG VPP_PAD(.P(), .PADR1(VPP));
PANALOG VNN_PAD(.P(), .PADR1(VNN)); |
