查看: 2835|回复: 2
[求助] 状态机时序问题
发表于 2014-4-7 22:02:04 | 显示全部楼层 |阅读模式
利用状态机设计时序电路用于检测二进制序列10010,Verilog 代码如下:module seqdet(x,clk,rst,z,state);
input clk,x,rst;
output z,state;
reg [2:0] state;
parameter IDLE='d0,A='d1,B='d2,
C='d3,D='d4,E='d5;
always @(posedge clk)
if(!rst)
state<=IDLE;
else
case(state)
IDLE
: if(x)
state<=A;
else
state<=IDLE;
A
if(!x)
state<=B;
else
state<=A;
B
if(!x)
state<=C;
else
state<=B;
C
:if(x)
state<=D;
else
state<=IDLE;
D
:if(!x)
state<=E;
else
state<=A;
E
:if(x)
state<=A;
else
state<=C;
default
state<=IDLE;
endcase
assign z=(state==D&&x==0)?1:0;
endmodule
其testbech测试模块源代码如下:
`timescale 1ns/1ns
module seqdet_tb();
reg clk,rst;
reg [23:0] data;
wire z,x;
wire [2:0] state;
assign x=data[23];
always #10 clk=~clk;
data={data[22:0],data[23]};
initial
begin
clk=0;
rst=1;
#2 rst=0;
#30 rst=1;
data='b1100_1011_0000_1001_0100;
#500 $stop;
end
seqdet m(.x(x),.clk(clk),.rst(rst),.z(z),.state(state));
endmodule
输出z能够满足,但是state的时序变化总是落后于数据x一个周期,求助解释!
发表于 2014-4-8 20:32:57 | 显示全部楼层
检测序列可以不用状态机写吧?
发表于 2014-4-9 13:05:34 | 显示全部楼层
感觉不用状态机更简单,x直接进移位寄存器比较就可以了
GMT+8, 2025-12-17 05:12 , Processed in 0.018430 second(s), 7 queries , Gzip On, Redis On.
