查看: 2171|回复: 1
[求助] FPGA VGA
发表于 2014-4-2 21:08:02 | 显示全部楼层 |阅读模式
module
VGA
VGA Side
oVGA_R,
oVGA_G,
oVGA_B,
oVGA_HS,
oVGA_VS,
oVGA_SYNC,
oVGA_BLANK,
oVGA_CLOCK,
Control Signal
iCLK,
iRST_N
VGA Side
output
reg
[9:0]
oVGA_R;
output
reg
[9:0]
oVGA_G;
output
reg
[9:0]
oVGA_B;
output
reg
oVGA_HS;
output
reg
oVGA_VS;
output
oVGA_SYNC;
output
oVGA_BLANK;
output
oVGA_CLOCK;
Control Signal
input
iCLK;
input
iRST_N;
Internal Registers
reg
[10:0]
H_Cont;
reg
[10:0]
V_Cont;
Horizontal
Parameter
parameter
H_FRONT
16;
parameter
H_SYNC
96;
parameter
H_BACK
48;
parameter
H_ACT
640;
parameter
H_BLANK
H_FRONT+H_SYNC+H_BACK;
parameter
H_TOTAL
H_FRONT+H_SYNC+H_BACK+H_ACT;
parameter   H_BAN=400;
Vertical Parameter
parameter
V_FRONT
11;
parameter
V_SYNC
2;
parameter
V_BACK
31;
parameter
V_ACT
480;//480
parameter
V_BLANK
V_FRONT+V_SYNC+V_BACK;
parameter
V_TOTAL
V_FRONT+V_SYNC+V_BACK+V_ACT;
assign
oVGA_SYNC
1'b1;
This pin is unused.
assign
oVGA_BLANK
= ~((H_Cont<H_BLANK)||(V_Cont<V_BLANK));
assign
oVGA_CLOCK
~CLOCK;
always @(posedge iCLK or negedge iRST_N)
begin
  if(!iRST_N)
        begin
        oVGA_R <= 10'd0;
        oVGA_G <= 10'd0;
        oVGA_B <= 10'd0;
        end
   else  begin
    //RGB信号在显示期间正常输出,行、场消隐期间被清零
     oVGA_R <= (H_Cont >= H_BLANK && H_Cont <= H_TOTAL &&
                V_Cont >= V_BLANK && V_Cont <= V_TOTAL )
                ? 10'd0 : 10'd0;
     oVGA_G <= (H_Cont >= H_BLANK && H_Cont <= H_TOTAL &&
                ? 10'd0 : 10'd0;
     oVGA_B <= (H_Cont >= H_BLANK && H_Cont <= H_TOTAL &&
                ? 10'd1 : 10'd0;
      end
end/*
assign
oVGA_R
10'd1000000000;
assign
oVGA_G
10'd1000000000;
assign
oVGA_B
10'd1000000000;*/
Horizontal Generator: Refer to the pixel clock
reg CLOCK;
always@(posedge iCLK)
CLOCK<=~CLOCK;
always@(posedge CLOCK or negedge iRST_N)
begin
if(!iRST_N)
begin
H_Cont
0;
oVGA_HS
1;
end
else
begin
if(H_Cont<H_TOTAL)
H_Cont
H_Cont+1'b1;
else
H_Cont
0;
Horizontal Sync
if(H_Cont<=H_FRONT-1)
Front porch end
oVGA_HS
1'b0;
if(H_Cont<=H_FRONT+H_SYNC-1)
Sync pulse end
oVGA_HS
1'b1;
end
end
Vertical Generator: Refer to the horizontal sync
always@(posedge oVGA_HS or negedge iRST_N)
begin
if(!iRST_N)
begin
V_Cont
0;
oVGA_VS
1;
end
else
begin
if(V_Cont<V_TOTAL)
V_Cont
V_Cont+1'b1;
else
V_Cont
0;
Vertical Sync
if(V_Cont<=V_FRONT-1)
Front porch end
oVGA_VS
1'b0;
if(V_Cont<=V_FRONT+V_SYNC-1)
Sync pulse end
oVGA_VS
1'b1;
end
end
endmodule
 楼主| 发表于 2014-4-2 21:08:50 | 显示全部楼层
我这样直接让显示屏显示一种颜色原理行吗?
GMT+8, 2025-12-22 20:24 , Processed in 0.016349 second(s), 6 queries , Gzip On, Redis On.
