楼主: mabas.masood
[其它] tsmc 130rf pdk
发表于 2014-11-27 04:04:55 | 显示全部楼层
You can convert CDB data to OA
By using cdb2oa tool included in cadence IC 6.1x
发表于 2014-12-3 05:27:38 | 显示全部楼层
楼主是不是把某个设计extraction的结果也考上去了?PDK怎么会这么大啊?
发表于 2014-12-4 03:27:00 | 显示全部楼层
Hi, I'm a new user of cadence and I need your help.
I have a problem in the third step for installing this PDK (TSMC130nm)
When I wrire tsmc13rf_updateCDFs(''TSMC130_PDK'') in CIW of cadence, I get this Error message:
*Error* eval : undefined function - tsmc13rf_updateCDFs
What's the problem? and how to do this step?
发表于 2014-12-4 03:27:51 | 显示全部楼层
回复 1# mabas.masood
 楼主| 发表于 2014-12-4 04:03:32 | 显示全部楼层
回复 84# Ryan67
    add tsmc library directly to cadence path
it is not
necessary install this pdk
发表于 2014-12-10 15:28:26 | 显示全部楼层
很好,就是包太多了
发表于 2014-12-22 23:01:19 | 显示全部楼层
好资料,谢谢上传
发表于 2015-1-3 11:41:43 | 显示全部楼层
谢谢分享
发表于 2015-1-6 02:06:13 | 显示全部楼层
回复 85# mabas.masood
   Hi mabas.masood,
   I installed the kit TSMC 0.13um PDK, and I got some ERROR and WRNING messages. But the simulation work with this kit and the result are plotted.
   Please,can you help me to remove this ERRORs and WARNINGs. this messages are:
ERROR (ADE-5066): Tool 'hspiceS'has not been registered.
ERROR (ADE-5067): Unable toinitialize tool 'hspiceS'; either tool class is not
        defined or tool is not registered.
*Error* The default SKILLgeneric function has not been defined for the function"asiEnvGetVar". Ensure that this function is called with the correctargument(s) (tool partition name).
And:
*WARNING* The display packetinformation 'creamshortDash_L' for 'display' was not found.
*WARNING* The display packetinformation 'golddots_S' for 'display' was not found.
*WARNING* The display packetinformation 'orangestipple0_S' for 'display' was not found.
*WARNING* The display packetinformation 'reddot3thickLine' for 'display' was not found.
*WARNING* The display packetinformation 'limecrossthickLine' for 'display' was not found.
*WARNING* The display packetinformation 'creamdot3shortDash' for 'display' was not found.
*WARNING* The display packetinformation 'graydot3thickLine2' for 'display' was not found.
*WARNING* The display packetinformation 'greendot3thickLine' for 'display' was not found.
*WARNING* The display packetinformation 'limedot3thickLine' for 'display' was not found.
*WARNING* The display packetinformation 'yellowdot3thickLine' for 'display' was not found.
*WARNING* The display packetinformation 'cyandot3thickLine' for 'display' was not found.
*WARNING* The display packetinformation 'magentadot3thickLine' for 'display' was not found.
*WARNING* The display packetinformation 'limebrickthickLine' for 'display' was not found.
*WARNING* The display packetinformation 'yellowdaggerthickLine' for 'display' was not found.
*WARNING* The display packetinformation 'magentastipple0thickLine' for 'display' was not found.
*WARNING* The display packetinformation 'limedot3_S' for 'display' was not found.
*WARNING*The display packet information 'pinkbrickdots' for 'display' was not found.
I will appreciate your help?
*WARNIN
ERROR
发表于 2015-1-12 18:31:39 | 显示全部楼层
楼主好人,不过下的好辛苦
GMT+8, 2025-12-22 06:01 , Processed in 0.017782 second(s), 3 queries , Gzip On, Redis On.
