楼主: mabas.masood
[其它] tsmc 130rf pdk
发表于 2014-9-24 15:36:39 | 显示全部楼层
PDK是什么
发表于 2014-10-12 20:57:56 | 显示全部楼层
好东西,谢谢
发表于 2014-10-13 22:08:57 | 显示全部楼层
回复 1# mabas.masood
   楼主,第24个分卷好像有问题啊。解压时报错。偏偏最重要的techfile刚好就在24分卷中,结果解压出来没有techfile,这样无法layout啊。楼主能帮忙解决一下吗?
发表于 2014-10-17 20:41:10 | 显示全部楼层
Convert .cdb libraries to oa (you can use this website as an example)
http://eda.engineering.wustl.edu ... ry_to_an_OA_library
发表于 2014-10-17 21:11:57 | 显示全部楼层
发表于 2014-10-17 21:19:52 | 显示全部楼层
eda.engineering.wustl.edu/wiki/index.php/How_to_convert_a_CDB_library_to_an_OA_library
发表于 2014-10-17 21:25:26 | 显示全部楼层
发表于 2014-10-17 21:30:12 | 显示全部楼层
How to convert a CDB library to an OA library
CDB
    Cadence Data Base format
OA
    Open Access format (now used in IC 6.1 and later)
To convert a CDB library to an OA library:
    First make sure that the DFII library is referenced in a cdb.lib file.
    Make a new directory for OA and cd to it.
    Next convert the technology library:
    cdb2oa -lib <techlib> -cdslibpath <path>
    Then convert the library of interest:
    cdb2oa -lib <library> -cdslibpath <path>
发表于 2014-10-17 21:34:54 | 显示全部楼层
For example, to convert the NCSU_TechLib_ami06 tech library from IC 5 to IC 6.1 do the following:
    Create a temporary directory to work in and change to that directory.
    mkdir $HOME/tmp
    cd $HOME/tmp
    Create directories cdb and oa directories and change directory to the cdb directory.
    mkdir cdb
    mkdir oa
    cd cdb
    Create a cds.lib file for the old NCSU_TechLib_ami06 tech library.
    vi cds.lib
    Enter the following:
    DEFINE NCSU_TechLib_ami06 $CDS_SITE_CONFIG/CDK/ncsu-cdk-1.5.1/lib/NCSU_TechLib_ami06
    Change directory to the oa directory. This can be done using a relative path.
    cd ../oa
    Execute cdb2oa to convert the tech library to the Open Access database format.
    cdb2oa -lib NCSU_TechLib_ami06 -cdslibpath ../cdb
    You should have a message that looks like this.
    <--cut-->
    Finished at:   Dec 13 19:45:39 2010
    80 cells and 80 cellviews were translated from library 'NCSU_TechLib_ami06' in 114.1s.
回复 支持 1 反对 1
发表于 2014-10-23 23:32:49 | 显示全部楼层
楼主大好人。
GMT+8, 2025-12-18 21:01 , Processed in 0.017777 second(s), 3 queries , Gzip On, Redis On.
