楼主: mabas.masood
[其它] tsmc 130rf pdk
发表于 2014-4-2 09:41:01 | 显示全部楼层
TSMC 0.13um CMOS Mixed-Signal/RF 1P8M/1P7M/1P6M
                       SALICIDE 1.2V/2.5V/3.3V FSG PDK (w/i UTM, w/o UTM)
              TSMC 0.13um CMOS Mixed-Signal 1P5M/1P4M
                        Version : V1.3b
                        Doc. #  : T-013-MM-SP-001-K1
                        Date    : July 09, 2007
多谢楼主分享!!
发表于 2014-4-2 09:41:44 | 显示全部楼层
This PDK has been tested to work with the following software versions:
  Cadence IC        5.10.41_USR2
  Assura        sub-version 33.1.4_USR2
  Calibre        6.0.2.119
发表于 2014-4-2 09:43:57 | 显示全部楼层
回复 9# chris2013
This PDK requires the following environmental variables:
"CDS_Netlisting_Mode" to be set to "Analog"
"CDSHOME" to be set to Cadence DFII installation path
Calibre  6.0.2.119
 楼主| 发表于 2014-4-2 12:17:07 | 显示全部楼层
回复 9# chris2013
    i converted to OA
if you need CDB please tell me to upload CDB version
发表于 2014-4-2 18:22:39 | 显示全部楼层
回复 14# mabas.masood
yes i need the CDB version
thanks in advance for your help
发表于 2014-4-2 18:27:57 | 显示全部楼层
yes please i need the CDB version
发表于 2014-4-2 22:27:35 | 显示全部楼层
非常好,谢谢!找了很久了
发表于 2014-4-2 22:30:48 | 显示全部楼层
this PDK has been tested to work with the following software  versions:
   Calibre        6.0.2.119
发表于 2014-4-2 23:09:20 | 显示全部楼层
回复 6# mabas.masood
大哥能不能给份design rule 啊?
 楼主| 发表于 2014-4-3 04:29:45 | 显示全部楼层
回复 15# chris2013
    i upload cdb in
http://bbs.eetop.cn/viewthread.php?tid=441386&extra=
GMT+8, 2025-12-18 22:55 , Processed in 0.019131 second(s), 3 queries , Gzip On, Redis On.
