查看: 2053|回复: 1
[求助] Xilinx v5 FPGA自定义IP核时,出现的问题
发表于 2014-3-19 10:58:15 | 显示全部楼层 |阅读模式
在自定义IP核时,出现这些错误提醒,而我自定义IP核时米有用到类似PLB_ABus的东西,且我在生成IP核时,已经把IP核挂在PLB总线上,不知道为什么在生成网表的时候出现这些问题,有遇到类似问题的吗?希望能得到您的帮助,先行谢过~
ERROR:Xst:2585 - Port <PLB_ABus> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_BE> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_MSize> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_PAValid> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_RNW> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_SAValid> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_TAttribute> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_UABus> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_abort> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_busLock> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_lockErr> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_masterID> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_rdBurst> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_rdPendPri> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_rdPendReq> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_rdPrim> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_reqPri> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_size> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_type> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_wrBurst> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_wrDBus> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_wrPendPri> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_wrPendReq> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <PLB_wrPrim> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <SPLB_Clk> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <SPLB_Rst> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_MBusy> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_MIRQ> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_MRdErr> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_MWrErr> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_SSize> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_addrAck> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_rdBTerm> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_rdComp> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_rdDAck> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_rdDBus> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_rdWdAddr> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_rearbitrate> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_wait> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_wrBTerm> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_wrComp> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:Xst:2585 - Port <Sl_wrDAck> of instance <tongxun_0> does not exist in definition <tongxun>. Please compare the definition of block <tongxun> to its component declaration to detect the mismatch.
ERROR:EDK:546 - Aborting XST flow execution!
ERROR:EDK:440 - platgen failed with errors!
 楼主| 发表于 2014-3-19 14:16:42 | 显示全部楼层
问题已经解决,出现问题的原因是我在user_logic实例化的名字与IP核名字重复,在IP核写时.vhd网表里已经实例化一次且和我IP核名字相同,造成冲突出现问题。
GMT+8, 2025-12-14 20:23 , Processed in 0.021651 second(s), 5 queries , Gzip On, Redis On.
