查看: 12439|回复: 22
[求助] VCS+verdi debug,VCS编译无法通过
发表于 2014-3-17 14:37:51 | 显示全部楼层 |阅读模式
make : *** [product timestamp] Error 1
make exited with status 2
求大牛指点~~
版本是VCS201103,verdi2011.想调用VERDI里面有很多vcs,vcsd,vcs_latest,vcs_mixed,vcs_miph..诸多版本.应选哪个呢?指定PLI时有debussy.tab,novas.tab.verdi.tab.fsdb_vcs.tab.fsdb_vcs.a.pli.a等.tab,.a文件,应选择哪个呢?谢谢啦~===========================================
以上版本和pli.a .tab都试过了,都不行
 楼主| 发表于 2014-3-17 22:26:51 | 显示全部楼层
compile log as follows.
*design* DebussyLib (btIdent 2011.04)
Command arguments:
    +define+verilog
    -inc
    /home/hu/test/sim/tb/dut.v
    /home/hu/test/sim/tb/uvm_tb_top2.v
*Error* File type not allowed for object.
"/home/hu/test/sim/tb/uvm_tb_top2.v", 1:
*Error*  syntax error (expecting keyword 'module', 'macromodule' or 'primitive')
"/home/hu/test/sim/tb/uvm_tb_top2.v", 2: import uvm_pkg:<-
*Error*  Resource file error (expecting keyword 'module', 'macromodule' or 'primitive')
"/home/hu/test/sim/tb/uvm_tb_top2.v", 11: interface my_if(input<-
"/home/hu/test/sim/tb/uvm_tb_top2.v", 13: logic [7:0] rxd<-
"/home/hu/test/sim/tb/uvm_tb_top2.v", 14: logic       rx_dv;<-
"/home/hu/test/sim/tb/uvm_tb_top2.v", 15: logic [7:0] txd<-
"/home/hu/test/sim/tb/uvm_tb_top2.v", 16: logic       tx_en;<-
"/home/hu/test/sim/tb/uvm_tb_top2.v", 18: clocking drv_cb@<-
"/home/hu/test/sim/tb/uvm_tb_top2.v", 22: clocking mon_cb<-
"/home/hu/test/sim/tb/uvm_tb_top2.v", 36: module<-
"/home/hu/test/sim/tb/uvm_tb_top2.v", 50: initial<-
"/home/hu/test/sim/tb/uvm_tb_top2.v", 56: end<-
"/home/hu/test/sim/tb/uvm_tb_top2.v", 59: uvm_config_db#(virtual my_if<-
"/home/hu/test/sim/tb/uvm_tb_top2.v", 62: uvm_config_db#(virtual my_if<-
"/home/hu/test/sim/tb/uvm_tb_top2.v", 65: end<-
"/home/hu/test/sim/tb/uvm_tb_top2.v", 72: end<-
"/home/hu/test/sim/tb/uvm_tb_top2.v", 88: class my_transaction extends<-
Total        21 error(s),   0 warning(s)
发表于 2014-3-18 10:38:23 | 显示全部楼层
看样子lz用的UVM1.1应用指南及源代码分析里的例子
 楼主| 发表于 2014-3-18 12:19:53 | 显示全部楼层
回复 3# seabeam
有什么解决方案吗,还有verdi里的PLI中VCS的多个版本 VCS,VCSD,MIXED,MHPI等等,不晓得是选哪个,我本人使用VCS201103版
 楼主| 发表于 2014-3-19 08:33:41 | 显示全部楼层
求大牛啊~~~~~~~
发表于 2014-3-19 08:50:21 | 显示全部楼层
-P  ***/novas/verdi***/share/PLI/vcs/LINUX/novas.tab
***/novas/verdi***/share/PLI/vcs/LINUX/pli.a
 楼主| 发表于 2014-3-19 10:01:38 | 显示全部楼层
回复 6# Reals_JIANG
   试了。还是不行。
发表于 2014-3-19 10:12:07 | 显示全部楼层
没用过verdi,看上去是编译问题?你确定没有语法问题么?而且你可以度娘或者谷歌一下嘛。例如:http://bbs.eetop.cn/thread-315538-1-1.html
 楼主| 发表于 2014-3-19 10:18:09 | 显示全部楼层
回复 8# seabeam
   确定没有语法问题。是PLI库问题。你给的链接我看了一下,应该不是那个帖子相似的问题,谢谢
发表于 2014-3-19 10:18:23 | 显示全部楼层
请LZ贴一下Makefile和compile的命令行?
GMT+8, 2025-12-19 05:22 , Processed in 0.022850 second(s), 5 queries , Gzip On, Redis On.
