查看: 13032|回复: 27
[讨论] MVSIM201209调用VCSMX201306
发表于 2014-3-11 10:55:55 | 显示全部楼层 |阅读模式
make -d makefile.ev all TOOL=vcs 总是失败,显示:
vcs -R +vpi -l transcript.log -load "libmvsim-vcs.so:mvsimInit"  -full64  -P apdb/ev/mvsim_vcs.tab    -file /home/zxbe/bk/i3bk/RD2LP/fe/mvt/apdb/ev/vcs_optfile_1
VCS_HOME = /home/tol/snps/vcs1306
Warning-[LNX_OS_VERUN] Unsupported Linux version
  Linux version 'CentOS release 6.5 (Final)' is not supported on 'x86_64'
  officially, assuming linux compatibility by default. Set VCS_ARCH_OVERRIDE
  to linux or suse32 to override.
  Please refer to release notes for information on supported platforms.
Warning-[FILE_64BIT] 64bit options not supported in -f/-file
  VCS 64bit option '-full64' is not supported in '-file' option.
  File name: '/home/zxbe/bk/i3bk/RD2LP/fe/mvt/apdb/ev/vcs_optfile_1'.
  Please specify the option in command line directly.
                         Chronologic VCS (TM)
         Version H-2013.06_Full64 -- Tue Mar 11 10:53:52 2014
               Copyright (c) 1991-2013 by Synopsys Inc.
                         ALL RIGHTS RESERVED
This program is proprietary and confidential information of Synopsys Inc.
and may be used and disclosed only as authorized in a license agreement
controlling such use and disclosure.
                    ArchPro MVSIM
        Version G-2012.09 for Linux 2.6.9-89.ELlargesmp -- 30 Aug, 2012
              Copyright (c) 2004-2012 by Synopsys, Inc.
                 ALL RIGHTS RESERVED
This software and the associated documentation are confidential and
proprietary to Synopsys, Inc. Your use or disclosure of this software
is subject to the terms and conditions of a written license agreement
between you, or your company, and Synopsys, Inc.
[MVSIM] INFO 571: INI file taken from 'cmvt1209/mvt1rtl.ini'.
[MVSIM] INFO 5026: MVSIM started with UPF_ON_OFF mode = Yes
Warning-[ACC_CLI_ON] ACC/CLI capabilities enabled
  ACC/CLI capabilities have been enabled for the entire design. For faster
  performance enable module specific capability in pli.tab file
Command line: /home/tol/snps/vcs1306/amd64/bin/vcs1 -Mcc=gcc -Mcplusplus=g++ -Masflags= "-Mcfl= -pipe -O -I/home/tol/snps/vcs1306/include " "-Mldflags= " -Mout=simv -Mamsrun= -Mvcsaceobjs= "-Mobjects= /home/tol/snps/vcs1306/amd64/lib/libvirsim.so /home/tol/snps/vcs1306/amd64/lib/liberrorinf.so /home/tol/snps/vcs1306/amd64/lib/libsnpsmalloc.so " -Msaverestoreobj=/home/tol/snps/vcs1306/amd64/lib/vcs_save_restore_new.o -Mcrt0= -Mcrtn= -Mcsrc= "-Msyslibs=-ldl -lm " -Xvcs_run_simv=1 -l transcript.log -load libmvsim-vcs.so:mvsimInit -full64 -P apdb/ev/mvsim_vcs.tab +libext+.v+.sv -full64 +vpi -sverilog -gen_obj /home/tol/snps/mvt1209/templates/upf_package.sv /home/zxbe/bk/i3bk/RD2LP/fe/mvt/apdb/ev/inp/RD2LPtb2mvs.v +incdir+/home/zxbe/bk/i3bk/RD2LP/fe/mvt/apdb/ev/incdir +incdir+/home/zxbe/bk/i3bk/RD2LP/fe/mvt/inp /home/zxbe/bk/i3bk/RD2LP/fe/mvt/apdb/ev/archudpxform/work.v
--- Stack trace follows:
[Thread debugging using libthread_db enabled]
[New Thread 0x2b36cd6a0700 (LWP 4484)]
[New Thread 0x2b36cea2d700 (LWP 4482)]
0x0000003c452accdd in nanosleep () from /lib64/libc.so.6
Thread 3 (Thread 0x2b36cea2d700 (LWP 4482)):
#0  0x0000003c452ac8fd in waitpid () from /lib64/libc.so.6
#1  0x0000003c4523e909 in do_system () from /lib64/libc.so.6
#2  0x0000003c4523ec40 in system () from /lib64/libc.so.6
#3  0x0000000003baf8b4 in tracker::StackAnnotator::getGdbOutput(char const*, char const*, char const*) ()
#4  0x0000000003bafe4b in tracker::StackAnnotator::dumpStackByGdb(char const*, char const*) ()
#5  0x0000000003bb0dea in tracker::StackAnnotator::dumpProcessStack(unsigned int, char const*, char const*) ()
#6  0x0000000003ba7356 in dumpStackTrace ()
#7  0x0000000003ba77f4 in ?? ()
#8  <signal handler called>
#9  0x00002b36cd90d8e8 in ?? ()
#10 0x00002b36cea2bac0 in ?? ()
#43 0x0000000000000000 in ?? ()
Thread 2 (Thread 0x2b36cd6a0700 (LWP 4484)):
#0  0x0000003c4560eb5c in recv () from /lib64/libpthread.so.0
#1  0x0000000003737ac8 in ?? ()
#2  0x0000000003737e2d in rt1tE6I7sRtuNh4 ()
#3  0x000000000372b783 in C34lja2TrlHEPKx ()
#4  0x000000000372a779 in ?? ()
#5  0x0000003c456079d1 in start_thread () from /lib64/libpthread.so.0
#6  0x0000003c452e8b6d in clone () from /lib64/libc.so.6
Thread 1 (Thread 0x2b36ccb05500 (LWP 4481)):
#0  0x0000003c452accdd in nanosleep () from /lib64/libc.so.6
#1  0x0000003c452acb50 in sleep () from /lib64/libc.so.6
#2  0x000000000361a7d5 in LLy8bjyG0uqiwBz ()
#3  0x000000000361a8c9 in bW7ifz5jPPyae3Z ()
#4  0x000000000361a130 in pizBhiy39Ywj9j ()
#15 0x0000000000cffdae in c_main ()
#16 0x00000000017a6706 in main ()
No context available
CPU time: 2.433 seconds to compile
make: *** [compile] Error 1
发表于 2014-3-12 10:55:22 | 显示全部楼层
先看error 再看warning 好像这个系统不是支持的系统
发表于 2014-3-12 16:58:08 | 显示全部楼层
不是很懂
发表于 2014-4-22 20:38:19 | 显示全部楼层
make -f makefile.ev all TOOL=vcsmx
发表于 2014-8-30 14:37:46 | 显示全部楼层
/tools/synopsys/vcs-mx/H-201306_64/bin/vcs: line 5986:  4587 Segmentation fault      (core dumped) /tools/synopsys/vcs-mx/E-201103/amd64/bin/vcs1 -Mcc=gcc -Mcplusplus=g++ -Masflags= -Mcfl=' -pipe -I/tools/synopsys/vcs-mx/E-201103/include -O4 -I/tools/synopsys/vcs-mx/E-201103/include ' -Mldflags=" " -Mout=simv -Mamsrun="" -Mvcsaceobjs="" -Mobjects=" /tools/synopsys/vcs-mx/E-201103/amd64/lib/libvirsim.so /tools/synopsys/vcs-mx/E-201103/amd64/lib/liberrorinf.so /tools/synopsys/vcs-mx/E-201103/amd64/lib/libsnpsmalloc.so /tools/synopsys/Verdi/E-201210/basic/share/PLI/VCS/LINUX64/pli.a " -Msaverestoreobj=/tools/synopsys/vcs-mx/E-201103/amd64/lib/vcs_save_restore_new.o -Mcrt0="" -Mcrtn="" -Mcsrc="" -Mupdate -Msyslibs="-ldl -lm -lm " +nospecify +notimingcheck -full64 +plusarg_save +vcs+lic+wait +v2k -P /tools/synopsys/Verdi/E-201210/basic/share/PLI/VCS/LINUX64/novas.tab -load ${ARCHPRO_ROOT}/amd64/lib/libmvsim-vcs.so:mvsimInit -P /tools/synopsys/mvtools/G20120901/templates/mvsim_vcs.tab -Xcbug=0x1 -l logfile/top_oled_asic.vcs.log +cli+4 +vcsd +itf+/tools/synopsys/vcs-mx/E-201103/amd64/lib/vcsd.tab +vpi -debug=3 +memcbk -sverilog +vpi +vpi -gen_obj -f ./apdb/ev/vcs_options_1 -f ./apdb/ev/cmdfile_1
CPU time: 18.573 seconds to compile
sh: /projs/xxx_digital/wa/xxx/R1.0/SIM/top/run/simulator_vcs.cmds: No such file or directory
tee: logfile/: Is a directory
    RTL simualtion done
simulation end
发表于 2014-8-30 14:39:44 | 显示全部楼层
MVTOOLS: 201306     VCS: 201106   GCC: 4.2.2
MVTOOLS+VCS混跑,MVCMP->MVDBGEN->MVSIM 全部完成,最后跑VCS出以上错误。
注意:跑小的项目没有问题,波型一切正常。跑大项目就如此了。
希望高手帮忙分析分析
发表于 2014-8-30 14:40:41 | 显示全部楼层
MVTOOLS: 2012/2013  VCS: 2011/ 2013 全跑过,结果依然
OS: redhat as 4.x  / 5.x
发表于 2014-8-30 14:48:23 | 显示全部楼层
实在没有招了,准备用:mvtools201206  +  vcs201206 搭合一起跑跑看。不能就准备换REDHAT AS6.X跑跑
发表于 2014-8-30 22:31:46 | 显示全部楼层
能否分享解决方法
发表于 2014-8-31 17:32:45 | 显示全部楼层
内存报错,完全找不方向。我还希望众位给意见呢
GMT+8, 2025-12-19 06:16 , Processed in 0.023121 second(s), 5 queries , Gzip On, Redis On.
