查看: 2043|回复: 0
[招聘] NO.78-HardwareEngineer(Shanghai)
发表于 2014-3-4 15:24:00 | 显示全部楼层 |阅读模式
1.Be responsible for hardware system design, discuss with chip designer, understanding their requirement and design the hardware system(schematic, PCB and C program) correspondingly
2. Testing the hardware system and provide test report
3. Debugging the system, discussing with chip designer and help chip designer debug the issues
要求:
1. B.S. in electrical engineering or equivalent is required
2. 2 or more years of PCB design experience is required
3. 2 or more years of C programming is required
4. DDR knowledge and testing experience is required
5. Experience of Xilinx/Altera FPGA is preferred
6. Experience of embedded system is preferred
7. Experience of using multimeter, waveform generator, oscilloscope is preferred
8. Verilog coding experience is preferred
PS:最好有 . DDR knowledge and testing experience is required
KT Human Resources Consulting Company (Shanghai) was established in 2001 in response to a need for a recruitment consultancy to be an active, contributing member of the semiconductor community, as opposed to simply a supplier to it.We provide professional search and talent acquisition in the Integrated Circuit、Electronic、Telecommunications industry of international corporations in Greater China. Our client list contains numerous international companies, many of them are long-term customers.
If you interested in the job, pls sent your cv to: hr@kthr.com, thanks!
“KT人才”微信也可查询职位啦!打开手机微信,搜号码“KTHR_COM”或查找微信公众帐号“KT人才”即可添加,欢迎大家关注!(关注成功后输入”KT“即可查询职位!)
GMT+8, 2025-12-25 14:08 , Processed in 0.010704 second(s), 3 queries , Gzip On, Redis On.
