查看: 20762|回复: 35
求 Catapult C v2013.x
发表于 2014-2-13 16:14:43 | 显示全部楼层 |阅读模式
CTOS Compiler, Cynthesizer 只能够支持 SystemC,俺不会
Synphony C Compiler 太烂,GUI会完全卡在 Schedule 不动,俺崩溃
最后只有求一个 Catapult C (Calypto收购以后的最新版本) 了,至少这个工具俺用得纯熟。。。
发表于 2014-2-13 16:23:34 | 显示全部楼层
用Catapult C同样也不能随心所欲的按着C++来写code。他们的最大优点都是综合,只是各个厂商的产品的特性不同。
 楼主| 发表于 2014-2-13 16:28:17 | 显示全部楼层
回复 2# 飞扬紫百合
实际上所有的工具都不能随心所欲。。。
我只是说我对 Catapult C 这个工具掌握的纯熟。
哈哈:)
发表于 2014-2-13 19:21:23 | 显示全部楼层
CatapultC is the best tool in the EDA world. I don't have access to the final release but I think it should support the C++11. It's wonderful! ha?
 楼主| 发表于 2014-2-13 22:20:05 | 显示全部楼层
回复 4# ald_syn_cad
so, could you share your latest Catapult C with us?
really appreciating :- )
发表于 2014-2-14 01:00:39 | 显示全部楼层
I have been using CatapultC for more than 3 years. There are unlimited number of questions about it. You can read some of them below (just simply register):
http://communities.mentor.com/mgcx/community/asic_fpga/esl
It supports most of verification and implementation flows that other tools do not. I think no body in the world could have any allegation that he or she knows it completely because of its unbelievable complexity.
If you are a person who wants to show himself an active member in IEEE (1 paper in a month related to the IP developing ) you have chosen the appropriate tool.
 楼主| 发表于 2014-2-14 11:50:40 | 显示全部楼层
回复 6# ald_syn_cad
i'm just a person who'd like to use it.
nothing else~ : )
发表于 2014-2-14 21:48:31 | 显示全部楼层
回复 1# yaoguaiws
    我看了,版上的2011a.183  (update 7)
就是目前能获得的最新的,时间是2013年4月发布的。
再就只能等着谁有权限更新的了。
 楼主| 发表于 2014-2-15 00:33:32 | 显示全部楼层
回复 8# jlqsczw_2007
继续等待 Calypto 的版本。。。
发表于 2014-2-15 02:45:28 | 显示全部楼层
The Catapult C version 2011a.183 (update 7) has been released in summer of 2013. In the installed program you'll see in the "About" Windows that the 2011a.183 (update 7) was released in 2013. It is possible, that this version is the latest released version.
Catapult C version 2011a.183 (update 7) download: http://bbs.eetop.cn/viewthread.php?tid=419244
GMT+8, 2025-12-27 01:03 , Processed in 0.028364 second(s), 6 queries , Gzip On, Redis On.
