查看: 2392|回复: 0
[求助] synopsys dc 安装求助
发表于 2014-2-8 18:27:07 | 显示全部楼层 |阅读模式
[root@localhost bin]#  0:38:01 (lmgrd) FLEXlm (v9.23) started on localhost.localdomain (linux) (2/9/2014)
0:38:01 (lmgrd) Copyright (c) 1988-2004 by Macrovision Corporation. All rights reserved.
0:38:01 (lmgrd) US Patents 5,390,297 and 5,671,412.
0:38:01 (lmgrd) World Wide Web:  http://www.macrovision.com
0:38:01 (lmgrd) License file(s): /usr/synopsys/license/Synopsys.dat
0:38:01 (lmgrd) lmgrd tcp-port 28001
0:38:01 (lmgrd) Starting vendor daemons ...
0:38:01 (lmgrd) Started snpslmd (internet tcp_port 58969 pid 4802)
0:38:01 (snpslmd) FLEXnet Licensing version v11.9.1.5 build 104455 i86_lsb
0:38:01 (snpslmd) lmgrd version 9.2, snpslmd version 11.9
02/09/2014 00:38:01 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_11.5
0:38:23 (snpslmd) License server system started on localhost.localdomain
0:38:23 (snpslmd) No features to serve, exiting
0:38:23 (snpslmd) EXITING DUE TO SIGNAL 36 Exit reason 4
0:38:23 (lmgrd) snpslmd daemon found no features.  Please correct
0:38:23 (lmgrd) license file and re-start daemons
0:38:23 (lmgrd)
0:38:23 (lmgrd) This may be due to the fact that you are using
0:38:23 (lmgrd) a different license file from the one you expect.
0:38:23 (lmgrd) Check to make sure that:
0:38:23 (lmgrd) /usr/synopsys/license/Synopsys.dat (null)
0:38:23 (lmgrd) is the license file you want to use.
0:38:23 (lmgrd)
GMT+8, 2025-12-26 12:41 , Processed in 0.014756 second(s), 7 queries , Gzip On, Redis On.
