查看: 3567|回复: 5
How to realize the Direct Dicision Mode of the lms- DFE equalizer ?
发表于 2014-1-24 20:25:20 | 显示全部楼层 |阅读模式
for the training mode, my model works well. When transfer to the Direct Decision Mode, I am confused about how to realize the Decision Device , specifically , I do not know how to choose the right reference value for decision. Channel is based on the single mode fiber with OOK modulation. Anybody has related experience please give me some kind of suggestion. Thanks in advance. Alternatively, we can discuss this together. DEF.JPG
发表于 2014-2-1 21:37:39 | 显示全部楼层
没研究过这个,帮你顶一下吧。
发表于 2014-2-8 17:53:54 | 显示全部楼层
I guess you were doing blind equalization using LMS-CMA Algorithm. I am pretty sure the correct reference signal can be determined by the training sequences (you finished) or detected the bit sequence. The taps of Directed Decision mode updates using the output of decision circuit as the estimation of the transmitted sequence.
发表于 2014-2-9 17:57:46 | 显示全部楼层
终于有人来这个版块了,还是个大牛。
发表于 2014-3-29 21:31:35 | 显示全部楼层
Reply 1 # suken
   goooooooooooooooodreading
发表于 2014-3-31 16:31:45 | 显示全部楼层
Is the problem sovled?
GMT+8, 2025-12-19 07:55 , Processed in 0.023453 second(s), 7 queries , Gzip On, Redis On.
