查看: 6059|回复: 3
verdi lmgrd The TCP port number in the license, 14451, is already in use.
发表于 2014-1-2 21:00:13 | 显示全部楼层 |阅读模式
19:34:31 (lmgrd) The TCP port number in the license, 14451, is already in use.
19:34:31 (lmgrd) Possible causes:
19:34:31 (lmgrd)    1) The license server manager (lmgrd) is already running for this license.
19:34:31 (lmgrd)    2) The OS has not "cleared" this port since lmgrd died.
19:34:31 (lmgrd)    3) Another process is using this port number (unlikely).
19:34:31 (lmgrd) Solutions:
19:34:31 (lmgrd)    1) Make sure lmgrd and all vendor daemons for this license are not running.
19:34:31 (lmgrd)
19:34:31 (lmgrd)    2) You may have to wait for the OS to clear this port.
19:34:31 (lmgrd) Retrying for about 5 more minutes
19:35:07 (lmgrd) Still trying...
19:35:25 (lmgrd) Still trying...
19:35:43 (lmgrd) Still trying...
19:36:01 (lmgrd) Still trying...
19:36:19 (lmgrd) Still trying...
19:36:37 (lmgrd) Still trying...
19:36:55 (lmgrd) Still trying...
19:37:13 (lmgrd) Still trying...
19:37:31 (lmgrd) Still trying...
19:37:49 (lmgrd) Still trying...
19:38:04 (lmgrd) Failed to open the TCP port number in the license.
不知道怎么办
发表于 2014-1-3 09:58:03 | 显示全部楼层
netstat -nlp |grep <port number>
if it exists ,  run 'lsof |grep <port number>' to check which procedure occupies the port number,  if that is license daemon, lmdown -c xxx.lic, then wait enough time  to restart your license daemon again. if not, you can kill it if it 's not necessary one.
发表于 2014-7-25 01:10:12 | 显示全部楼层
回复 2# phoenixson
I had similar issue with Questasim, and your solution was working.Thank you very much!
发表于 2016-5-15 20:12:54 | 显示全部楼层
不错~~~~~~~
GMT+8, 2025-12-23 16:14 , Processed in 0.036304 second(s), 6 queries , Gzip On, Redis On.
