查看: 2752|回复: 0
[求助] 有辦法把GDS VIEWER 搬到 android ?
发表于 2013-12-19 15:04:54 | 显示全部楼层 |阅读模式
http://www.stabie-soft.com/slfreeview.html
ssviewer        is a reduced capability completely free version of our        slam-view IC mask viewer.        The free version does not provide the follwoing features that        come with the paid version:
* Cross sectional viewing
* Loading/viewing of DRC error results from 3rd party DRC systems
* Tcl access to the database
All other features in the paid version are in the free version.
Select    the appropriate version
64 bit linux 2.6 kernel,
64 bit linux 2.4+ kernel,
32 bit linux 2.2+ kernel or
ARM 32 bit linux 3.6 kernel(raspberry pi)
    and install by untar-ing the file and add the directory {installedAt}/ssfre/bin to your    search path. Start the program by typing the command ssviewer. The menu has    a command Stream In, which can be used to convert a stream file to the    Stabie-Soft data format. After conversion, simply open the structure    that you want to look at. You can get more information by looking at the    ascii help files in the /ssfre/doc directory, starting with the    slam.doc file. These files can also be viewed inside ssviewer with the command
=>  不知道有沒有 ANDROID OS 能使用 VIEWER ?
GMT+8, 2025-10-23 07:43 , Processed in 0.016299 second(s), 6 queries , Gzip On, Redis On.
