查看: 11885|回复: 10
[求助] icc中set_fix_hold的意思
发表于 2013-12-18 23:10:02 | 显示全部楼层 |阅读模式
icc中set_fix_hold的意思是修善hold time还是固定hold time???
发表于 2013-12-19 08:51:43 | 显示全部楼层
   NAME
set_fix_hold
Sets the fix_hold attribute on clocks in the current design.
SYNTAX
status set_fix_hold    clocks
ARGUMENTS
clocks
Specifies the clocks on which to set the fix_hold attribute.
DESCRIPTION
This command sets the fix_hold attribute on the specified clock objects in the current design. The fix_hold attribute informs optimization that hold time violations of the specified clocks should be fixed.
Fixing a hold violation requires slowing down data signals. Optimization fixes hold violations while fixing the design rules, but only if the maximum delay cost is not increased or if the set_cost_priority command is used to prioritize hold violations ahead of maximum delay cost. Optimization can violate setup and fix hold as long as the worst negative slack (WNS) is not made worse. Optimization might fix hold and violate setup on noncritical paths.
The report_clock -attributes command identifies the clocks that have the fix_hold attribute.
Use the remove_attribute command to remove the fix_hold attribute.Multicorner-Multimode Support
This command applies to the current scenario only.
EXAMPLES
The following command sets the fix_hold attribute on clock clk1.   prompt> set_fix_hold clk1
The following command removes the fix_hold attribute from clock clk1.   prompt> remove_attribute [get_clocks clk1] fix_hold
发表于 2013-12-19 14:17:13 | 显示全部楼层
回复 1# Ronaldomhs
   1. 固定hold time 这个概念是不对的。
   2. hold time 是 foundry 库中cell 的时序参数。
   3. set_fix_hold 设置这个属性即是告诉工具,要在PR时优化hold time。使之满足timing 要求。
 楼主| 发表于 2013-12-19 21:12:48 | 显示全部楼层
回复 3# shaneami
    谢谢回答
发表于 2013-12-25 16:59:01 | 显示全部楼层
你们一般什么时候用这个命令?
我以前在做cts的时候用,感觉不好,工具似乎会放很多反相器和buff进去
发表于 2013-12-26 23:24:38 | 显示全部楼层
回复 5# 995331220
    我们一般都是sign off流程去fix hold,前提肯定是hold violation 数量还可以接受的情况下
发表于 2013-12-27 09:47:30 | 显示全部楼层
回复 6# xylyc521
   嗯 我也是,前面的都不修hold滴!
发表于 2017-5-1 10:33:51 | 显示全部楼层
学习了,
发表于 2017-5-2 01:45:13 | 显示全部楼层
回复 3# shaneami
thanks for the response.where could I find man pages for ICC/ICC2 commands?
发表于 2017-8-28 14:43:11 | 显示全部楼层
thanks too!
GMT+8, 2025-12-29 04:42 , Processed in 0.020141 second(s), 5 queries , Gzip On, Redis On.
