楼主: Apenper
[讨论] 设计的折叠共源共栅vds>vgs-vth却是线性区,vds<vdsat
 楼主| 发表于 2013-12-21 11:24:57 | 显示全部楼层
回复 17# feynmancgz
    Actually,I don't know why shouldn't use the bias of the cascode,because of the resistance???if i put the mosfet instead of resistance?  and  can you give me some better solution of bias circuit. i  just imitate the book of Alen.
发表于 2013-12-21 15:43:05 | 显示全部楼层
回复 21# Apenper
   As I said, it's ok, but better not use it. Apparently, it's because of the resistor. matching, area, swing....many problems. if you do layout, you will find out that adding a resistor there looks very strange.    I didn't insist you to give up using this bias circuit, actually you can. I just don't like it according to my experiences.
    Sorry, I can give you some advice, point out the problems you may have, but I won't give you solutions directly.
 楼主| 发表于 2013-12-21 20:32:55 | 显示全部楼层
OK ,  I just try change the bias circuit
发表于 2014-3-13 14:55:42 | 显示全部楼层
有些乱阿....VDS>VDSAT ,,,保和。
发表于 2014-3-13 16:45:05 | 显示全部楼层
GMT+8, 2025-9-20 18:26 , Processed in 0.014640 second(s), 3 queries , Gzip On, Redis On.
