查看: 2879|回复: 7
[招聘] 某外资企业需求Physical Design 数位-求招呼
发表于 2013-12-10 17:55:53 | 显示全部楼层 |阅读模式
SOC-RIP Physical Design Team
Position:Principal/Lead Physical Design Engineer
Position Description:
Perform  physical design implementation, including synthesis, floor planning, power  grid design, place and route, clock tree synthesis, timing closure,  power/signal integrity signoff, physical verification (DRC/LVS/Antenna),  EM/IR signoff, DFM Closure, and physical design project management.
The candidate will have the opportunity to work on many varieties of  challenging designs, i.e. low power and high speed design. The responsibility  includes participating in or leading next generation physical design,  methodology and flow development.
Position  Requirements:
BS‘  degree with 5~10+ years of applicable experience, MS’ degree with 3~7+ years  of applicable experience in electrical engineering, microelectronics.  Experienced with ASIC design flow, hierarchical physical design strategies, and  methodologies and understand deep sub-micron technology issues. Solid  knowledge on LP Design, DFT, static timing analysis, EM/IR-Drop/crosstalk  analysis, formal verification, physical verification, DFM. Successful track  records of taping out complex, 65/40/28 nm SOC chips. Automation and  programming-minded, solid coding experience in Makefile/Tcl/Tk/Perl.  Self-motivated, able to work independently or as a team player, excellent  verbal and written communication skills in English.
Please contact Annie Song:  012-63511401*812
 楼主| 发表于 2013-12-10 18:14:55 | 显示全部楼层
想看机会的伙伴们,可看起来了.. 可谈年后入职...
发表于 2013-12-26 12:00:33 | 显示全部楼层
楼主咋也不给个沙发啊···顶一顶啊···
发表于 2013-12-26 12:49:02 | 显示全部楼层
哪的职位?
 楼主| 发表于 2013-12-27 18:18:56 | 显示全部楼层
回复 4# fksnb
   公司名子小窗给你,但我们的客户都是外资半导体公司,所以平台都还不错。
发表于 2013-12-27 21:12:45 | 显示全部楼层
synapse的到你碗里了没?
 楼主| 发表于 2013-12-30 15:49:52 | 显示全部楼层
回复 6# angangang3484
   么得... 是碗不够大么?还是什么..
 楼主| 发表于 2014-9-18 15:55:38 | 显示全部楼层
我一直在找,一直在找,一直在找~
GMT+8, 2025-12-26 22:24 , Processed in 1.889732 second(s), 6 queries , Gzip On, Redis On.
