查看: 6603|回复: 6
Error: Segmentation fault.
发表于 2013-12-2 14:39:10 | 显示全部楼层 |阅读模式
Hi,I try run verilogA code in IC615. I get (SPECTRE-18) SEGMENTATION FAULT error. or sometime fatal error ADE-3069.
发表于 2013-12-2 18:05:04 | 显示全部楼层
内存不够用,或者访问冲突,有时是硬件问题,有时是软件bug,或者权限问题
发表于 2013-12-3 11:20:32 | 显示全部楼层
应该是库文件版本不对,看看有没有提示libxxx.oxx有问题,然后yum install
 楼主| 发表于 2013-12-3 14:50:20 | 显示全部楼层
it is working suddenly. i dont know what happened. the other cell view does not work. so i copy one cell view and re-use it.
发表于 2013-12-6 20:06:38 | 显示全部楼层
灌水灌水
发表于 2013-12-6 20:07:34 | 显示全部楼层
灌水灌水
发表于 2015-10-4 20:38:44 | 显示全部楼层
wo在存文件是做check时也出现这个问题,why?
GMT+8, 2025-12-20 19:30 , Processed in 0.017064 second(s), 5 queries , Gzip On, Redis On.
