查看: 2937|回复: 2
[求助] RTL实现时浮点数的定点化有哪些方法?
发表于 2013-11-8 15:23:36 | 显示全部楼层 |阅读模式
RT------------------
发表于 2013-11-9 00:22:18 | 显示全部楼层
我只知道移位
发表于 2013-11-9 11:03:50 | 显示全部楼层
http://en.wikipedia.org/wiki/Q_(number_format)
Q is a fixed point number format where the number of fractional bits (and optionally the number of integer bits) is specified. For example, a Q15 number has 15 fractional bits; a Q1.14 number has 1 integer bit and 14 fractional bits. Q format is often used in hardware that does not have a floating-point unit and in applications that require constant resolution.
GMT+8, 2025-12-4 05:10 , Processed in 0.012334 second(s), 3 queries , Gzip On, Redis On.
