查看: 12779|回复: 35
Antenna Magus Profesional 4.5.1
发表于 2013-10-29 06:53:23 | 显示全部楼层 |阅读模式
because nobody needs it with out crack i have deleted then..
发表于 2013-10-29 07:26:33 | 显示全部楼层
without crack?
发表于 2013-10-29 08:57:27 | 显示全部楼层
必须用Google浏览器才行
发表于 2013-10-29 13:15:13 | 显示全部楼层
Thanks very much for providing this good software , but without CRAck , does not work ,we need a  generous person to provide crack.
发表于 2013-10-29 20:04:32 | 显示全部楼层
下载的是安装包,没有pj文件
发表于 2013-11-27 23:14:34 | 显示全部楼层
什么东东?这么快就消失了?
 楼主| 发表于 2013-11-29 03:13:44 | 显示全部楼层
i have the installation files for the last release and the license manager installer but i did not have the crack, and i'm looking for the solution and making some tests of reverse the program but not success at this time.. i uploaded here before but the people don't like it because there was not crack inside and that's why i removed.. i'm able to share to anyone that could help to crack this software....
发表于 2014-1-30 18:24:26 | 显示全部楼层
ulisse, how did you downloaded the setup file since the link http://www.antennamagus.com/downloads/Antenna-Magus(Professional).exe is NOT working anymore? Why this software is still not cracked?
发表于 2014-2-22 19:08:16 | 显示全部楼层
谁能够把PJ 版的,V4.2以上的发到网上,那就太好了。
可惜一直没有找到。
发表于 2014-2-25 15:51:38 | 显示全部楼层
no Crack yet??
GMT+8, 2025-12-25 00:23 , Processed in 0.024095 second(s), 4 queries , Gzip On, Redis On.
