查看: 2757|回复: 2
[求助] encounter pin access problem
发表于 2013-10-28 17:16:34 | 显示全部楼层 |阅读模式
我有一個40nm的case , 繞現時遇到下面問題 pin access problem
#WARNING (NRDR-96) Cannot access INSTANCE_PIN B0  of INSTANCE u_xxx_core/u_xxx_top/u_dmg/skyd/U52084 on NET u_xxx_core/u_xxx_top/u_dmg/skyd/n44281 in area[2528.400 2362.795 2534.700 2368.800]
#WARNING (NRDR-97) NET u_xxx_core/u_xxxx_top/u_dmg/skyd/n44281 is set to open due to pin access problem.
請問高手該怎麼解 ?
发表于 2014-8-7 11:17:48 | 显示全部楼层
sorry i do not know.
发表于 2014-8-7 15:05:48 | 显示全部楼层
有route guide挡住了吧,
是stdcell还是macro pin, lef的问题?
到最后route结束再说吧
GMT+8, 2025-12-28 22:27 , Processed in 0.050596 second(s), 7 queries , Gzip On, Redis On.
