查看: 12828|回复: 10
[求助] 麻烦高手指点,Calibre PEX成功但后仿不成功报错如下
发表于 2013-10-6 21:12:02 | 显示全部楼层 |阅读模式
Begin Incremental Netlisting
ERROR (OSSHNL-249): There is no corresponding terminal for 'gnd' (on placed master ' ') in
switch master 'inv/calibre'. Netlisting will continue if this terminal can be
ignored. Otherwise, ensure that you have a corresponding terminal in switch
master and netlist again.
ERROR (OSSHNL-249): There is no corresponding terminal for 'in' (on placed master ' ') in
ERROR (OSSHNL-249): There is no corresponding terminal for 'out' (on placed master ' ') in
ERROR (OSSHNL-249): There is no corresponding terminal for 'vdd' (on placed master ' ') in
WARNING (ADE-6001): The number of terminals specified in CDF termOrder are more
           than the actual number of terminals in the cellview cell-view "test" "inv" "calibre"
WARNING (ADE-6004): Mismatch was found between the terminals in the cellView and those on the
           termOrder property on the CDF. Because of the mismatch, the CDF termOrder will
           be ignored. The terminals in the cellView will be netlisted in the alphabetical
           order of their names. Eliminate the mismatch if you want the CDF termOrder
           property to be used for netlisting.
           To edit CDF of a cell,
           i) Open CIW->Tools->CDF->Edit.
           ii) Select Library Name & Cell Name.
           iii) Click on the Edit button in the simulation information section of the
                Edit CDF window.
End netlisting Oct  6 20:46:52 2013
ERROR (OSSHNL-514): Netlisting failed due to errors reported before. Netlist may be corrupt or may not be produced at all. Fix reported errors and netlist again.
      ...unsuccessful.
发表于 2015-1-1 20:49:26 | 显示全部楼层
请问这个问题最后解决了吗?
发表于 2015-1-6 14:10:09 | 显示全部楼层
回复 2# 小支
    因为不是用calibre的,所以完全对应的解决方法给不出来。从提示上看是“vdd”“gnd”“out”等端口没有对应,检查一下提取出的网表里节点命名是否统一。
发表于 2015-1-7 19:42:25 | 显示全部楼层
不要用小写字母做PIng  换大写的再跑次
回复 支持 2 反对 0
发表于 2016-3-17 14:34:33 | 显示全部楼层
后来是如何解决的啊?
发表于 2016-9-28 20:33:20 | 显示全部楼层
4楼正解!
发表于 2017-4-26 11:18:06 | 显示全部楼层
回复 4# 这么简单
为什么不能用小写
发表于 2017-8-5 10:44:20 | 显示全部楼层
楼主,问题如何得到解决的?请知悉,谢谢赐教!
发表于 2018-4-12 00:12:30 | 显示全部楼层
4楼真强,按照他的方法解决了,非常感谢。
发表于 2021-4-27 19:53:39 | 显示全部楼层
腻害!!
GMT+8, 2025-12-23 02:52 , Processed in 0.024000 second(s), 6 queries , Gzip On, Redis On.
