查看: 1870|回复: 4
[讨论] Designing 1810 to 1880MHz amplifier
发表于 2013-10-2 15:56:53 | 显示全部楼层 |阅读模式
Hi,
I want to design DCS amplifier using MRF8S18120H and MRF6S18060N.
I designed amplifer using MRF6S18060N on FR4 sheet. I wan not able to achieve full gain specified in datasheet. i got only 10 to 11 db gain insted of 15.
There are issues in designing matching circuit  in ADS Momentum. I have issue in placing the ports in ADS Momentum internal or at the edge.
MRF6S18060N.pdf
761.55 KB, 下载次数: 9 , 下载积分: 资产 -2 信元, 下载支出 2 信元
MRF8S18120H.pdf
409.42 KB, 下载次数: 6 , 下载积分: 资产 -2 信元, 下载支出 2 信元
port issue .ppt
317.5 KB, 下载次数: 14 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2013-10-4 13:48:30 | 显示全部楼层
as I knew you do not have to add port2 for simulating capacitor, you can just add a capacitor component in momentum
发表于 2013-10-8 11:53:56 | 显示全部楼层
you should add pad for capacitance and use internal port.
发表于 2016-5-22 14:15:27 | 显示全部楼层
THANK YOU
发表于 2016-5-27 17:36:50 | 显示全部楼层
问的好。支持!
GMT+8, 2025-9-29 07:24 , Processed in 0.103252 second(s), 5 queries , Gzip On, Redis On.
