查看: 5020|回复: 4
[求助] [求助]反相器 Calibre LVS报错
发表于 2013-9-22 20:39:45 | 显示全部楼层 |阅读模式
刚开始学习版图,简单画了个反相器,好不容易过了DRC,现在LVS又卡住了。LVS report 如下,还请高手指导,谢谢!
Error:    Instances of different types or subtypes were matched.
LAYOUT CELL NAME:         inv
SOURCE CELL NAME:         inv
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:              4         4
Nets:               4         4
Instances:          0         1    *    MN (4 pins)
                     1         0    *    n11lvt_ckt (4 pins)
                     0         1    *    MP (4 pins)
                     1         0    *    p11lvt_ckt (4 pins)
Total Inst:         2         2
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:              4         4
Nets:               4         4
Instances:          1         1         _invv (4 pins): in out sup1 sup2
Total Inst:         1         1
       * = Number of objects in layout different from number in source.
                                 INCORRECT OBJECTS
LEGEND:
  ne  = Naming Error (same layout name found in source
        circuit, but object was matched otherwise).
                                 INCORRECT INSTANCES
DISC#  LAYOUT NAME                                               SOURCE NAME
  1    (_invv)                                                   (_invv)
         bad component type
       Devices:
         X1(-2.080,-2.020)  p11lvt_ckt                             MX1  MP(P11LVT_CKT)
         X0(-2.080,-2.876)  n11lvt_ckt                             MX0  MN(N11LVT_CKT)
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:               4          4            0            0
   Nets:                4          4            0            0
   Instances:           1          1            0            0    _invv
   Total Inst:          1          1            0            0
o Initial Correspondence Points:
   Ports:        VDD GND IN OUT
                                         SUMMARY
Total CPU Time:      0 sec
Total Elapsed Time:  0 sec
发表于 2013-9-23 09:31:43 | 显示全部楼层
某个标示层没画吧,具体是哪层要看layout rule
发表于 2013-9-23 17:15:40 | 显示全部楼层
你高压层没画吧?找个库里你要画的N管和P管类型,看看layout层次结构
 楼主| 发表于 2013-9-24 08:40:34 | 显示全部楼层
回复 2# 小YY
    问题解决了,是工艺库的问题。感谢你提出的排错思路,谢谢!
 楼主| 发表于 2013-9-24 08:43:30 | 显示全部楼层
回复 3# hitmic
    问题解决了,是工艺库没有配好,搞乱了。这个是Low Vt的。感谢你提出的排错思路,谢谢!
GMT+8, 2025-12-23 14:03 , Processed in 0.020280 second(s), 5 queries , Gzip On, Redis On.
