查看: 3974|回复: 2
[招聘] Marvell HR 招聘前、后端工程师 & Validation Engineer
发表于 2013-9-6 15:59:14 | 显示全部楼层 |阅读模式
If you have any interestin the position, please send your bilingual resume as
attachments to
al-china-hr@marvell.com
Subject of your email should be “YourName_University_Applied Position Title”
1\Job Title: Physical Design Engineer
Department:COT PD-SH -MTSL
Job Description:
PhysicalDesign Engineer will support physical design requirement of different businessunit of Mavell, the main responsibility is:
physicalimplementation, including floorplan, power routing, placement, clock treesynthesis, timing closure, routing, si fixing, drc fixing, dfm ...etc
physicalverification: including low power check, timing analysis, timing eco, xtalkanalysis, power analysis, ESD analysis, EM analysis, drc check, lvs check, antcheck, erc check ...etc
tapeout:timing signoff, power signoff, design tapeout... etc
Qualification:
BS/MS inEE/CS required.
Someknowledge and some experience on process, parameters, synthesis, timinganalysis, placement, routing, CTS, SI, power calculation, custom layout, timinganalysis and DRC/LVS.
Familiarwith Cadence, Synopsys, Mentor, Magma, Apache… EDA tools and design flow;
Familiarwith Verilog HDL, Spice
Goodprogramming skill. Capable of writing Tcl or Perl.
Self-motivatedteam worker, good verbal and written communication skills in English
2\Job Title: Engineer, Senior ASIC Design
Department: CentralEngineering
Job Description:
As a Digital designengineer, he/she will contribute to the overall SoC development and IPdevelopment for the micron-controller oriented SoC Product line, which includesblock level micron-architecture design, RTL coding, Simulation, SoC top levelintegration, verification and chip bring-up.
Qualification:
BSdegree in Electrical Engineering +5 years experience (or MS + 3 years) orequivalent in hardware development and system architecture.
Familiar with ASIC designmethodologies and flows.
Experience in the usageof state-of-the-art design tools.
Proficient in behavioraland RTL coding, Verification. Verilog is preferred
  Experience in logic synthesis, timingclosure.
Experience in Design ForTest.
Knowledge of Low Powerarchitecture and design practice is desirable.
Strong verbal and writtencommunication skills and proactive team-work spirit.
Working understanding ofvarious system interconnect protocols such as: AHB, AXI, OCP, APB, and theirimpact on IP development.
3/Job Title: Software developer forLinux BSP and Android
Department:AP System Engineering
Description,
In this position, you will be working with the platform architects,technical leaders and other developers to contribute to embedded Linux BSP/Androidand platform software development. You will be responsible for the detaileddevelopment specifications (example, component Low Level Design) and unit testplans, participating in BSP software implementation for handheld and/orcellular platforms and work with the validation team to ensure the product isthoroughly tested and meets established release criteria.
The candidate is expected to have below extraqualifications:
Master inElectronic Engineering or Computer Science major or with relevant experience.
ARM orembedded experiences
Strongprogramming and debugging skills in C/C++
Linux Kernel/Driverdevelopment experiences
Hardwaredebugging experience or board design experience is a plus
Multimediaframework GStreamer, OpenMAX or DirectShow is a plus
Fluentcommunication in both Mandarin and English is a plus.
4
Job Title: SoftwareEngineer in Test
Department: AP System Engineering
Description,
In theposition, the candidate will be responsible for creating  and executing the test suite/cases, test tools,and automation system to assure the quality of software platforms, which covercomponents from low level boot-loader, device driver, OS, middleware(multimedia and graphics), and up to high level application framework (likeAndroid), and Marvell proprietary compiler/debugger/performance tools.
His/herresponsibilities will include but not be limited to
l
Identifythe functionality, stability, performance and power quality criteria for thewhole system or individual components;
l
Execute testsuites to reach defined test coverage and debugging requirement.
Thecandidate is expected to have below extra qualifications:
l
Programmingskill in C, C++ and scripting language, i.e. Perl, python, is a must.
l
Knowledgeor working experience in projects similar to above projects is preferred.
l
Experiencein general embedded software development/debugging/validation and itsautomation is a plus.
l
Leadershipexperience in either software validation or development is a plus.
l
Technicalinfluence and interpersonal influence experience in multi-national company is amust. (English and Mandarin)
QQ:1552937745
MSN: domiliu0801@hotmail.com
更多Marvell招聘职位,请访问
http://marvell.cnstaff.com/
发表于 2013-9-6 16:17:48 | 显示全部楼层
回复 1# Domiliu
    这是校招嘛?
发表于 2013-9-6 16:30:38 | 显示全部楼层
是校招么?
GMT+8, 2025-12-23 22:44 , Processed in 0.041568 second(s), 6 queries , Gzip On, Redis On.
