楼主: tiejiayiran
[求助] PLL内的电容电阻对BW的影响
发表于 2013-8-31 06:27:50 | 显示全部楼层
回复 10# ygchen2
    Assume a linear system Y=H*X, H = 1st ~ nth  order
    Derive H=Y/X in Laplace s-domain
    Then transfer H back to the time domain
    You can get several term with different time constant.
    Since smaller time constant will decay faster (you can see these term to be the system transition).
    You can approximate the system time constant to be the maximum time constant.
     In this analog PLL case, X = input clock, Y = output clock, H = PLL system
发表于 2013-9-1 10:31:18 | 显示全部楼层
H of PLL system is NOT the same as LPF RC, VCO is another order of low pass on top of RC filter itself...and Kcp and Kvco are also very important on loop gain which affect the PLL BW for sure...-->The conclusion is PLL BW is NOT a simple RC low pass filter, a lot more are involved actually for the PLL BW, thus the conclusion on the relationship between the filter RC and PLL BW could be correct ONLY when the loop filter is plugged in a more specific PLL system. In other words, the relationship could be different on different PLL system providing that you need to make the PLL stable first, otherwise the BW means nothing at all.
如果可能还是用中文交流比较好。这样对论坛兄弟们可能会方便些。
发表于 2013-9-1 11:08:03 | 显示全部楼层
開迴路 BW 就是跟 lock time 有關 怎麼會不重要?
PLL 系統是負回授系統 Kvco等參數當然必須在迴路函數中 我說的H是用輸入跟與輸出看 相位微分就是角速度  鎖相就會鎖頻 你推導一下數學就會了解 這完全與OP負回授是同一件事 H 的setting time 就是 PLL 的setting time 這是數學問題 PLL當然不會是一階系統 但是自外面看就跟濾波器一樣(當然不是一階這麼簡單) 麻煩推導一下數學
发表于 2013-9-1 11:20:37 | 显示全部楼层
回复 13# 朱立平
    由輸入與輸出看 w_in(t) w_out(t) 類比式 PLL就是一個 有gain (M/N or fractional-N) 的 filter
发表于 2013-9-1 11:29:09 | 显示全部楼层
PLL 系統是負回授系統 Kvco等參數當然必須在迴路函數中 ...
朱立平 发表于 2013-9-1 11:08
如果没搞清H是什么的情况下数学是帮不了忙的。。。只有把H完整带进去再去导数学而且限制条件是系统phase Margin一定做为先决条件,可能这时导出的关系才可能有意义。。。否则可能越导数学距实际可用的PLL越远,要它何用?恐怕只能是为导数学而导数学了,因为它只是一座漂亮的“空中楼阁”,并没有实际实用价值。。。
BTW, it seems better to discuss in English if you like...
发表于 2013-9-1 11:38:40 | 显示全部楼层
H在以下連結有答案
http://wenku.baidu.com/view/dd833dd284254b35eefd3495.html
做類比電路數學有大用 千萬不能輕視數學
发表于 2013-9-2 08:02:33 | 显示全部楼层
H在以下連結有答案
做類比電路數學有大用 ...
朱立平 发表于 2013-9-1 11:38
数学大有用----完全同意。
数学在工程中是有力工具不假,甚至不可或缺,但运用是否得当却直接决定了数学是否可以发挥其应有的作用,如果运用不当甚至会受到误导。。。目标设定明确,工具运用得当,在解决工程问题中缺一不可。。。
发表于 2013-9-2 09:04:30 | 显示全部楼层
回复 14# 朱立平
    看来这位兄弟来自台湾
发表于 2013-9-2 11:32:36 | 显示全部楼层
回复 16# 朱立平
    麻烦您还是用英文把,你的繁体字看的头晕
发表于 2013-9-2 11:46:20 | 显示全部楼层
Ok, no problem!
GMT+8, 2025-12-30 10:33 , Processed in 0.021253 second(s), 3 queries , Gzip On, Redis On.
