查看: 2092|回复: 3
[招聘] 【Marvell】急招Engineer, Validation/Application Engineer
发表于 2013-8-27 17:15:56 | 显示全部楼层 |阅读模式
Job Title:  Engineer, Validation/Application Engineer
Department: Channel System
Description:
Department profile: Silicon Validation Engineering group for Read Channels is responsible for validating all read channel devices designed by Marvell.
The activities also include performance measurement and automation of the tools used for validating the read channel.
The group is also responsible for the hardware and software design of all tools required for the above two activities.
Qualifications:
- M.S.E.E 2+ years’ experience.
- Direct experience with Read Channels and hard disk drives is a desired, but not required. Proficiency with C and Matlab is required.
- General hardware design experience is required. Some experience working in an IC testing environment with equipment such as Oscilloscopes and AWG's required.
Responsibility:
- Design and execute system level tests for complex mixed signal ICs using standard test equipment such as Oscilloscopes, network analyzers, etc.
- Work with designers to debug, understand and document new designs.
- Provide technical documentation, descriptions and information to Field Application Engineers, Test Engineers and customers.
- Write and maintain software used to automate bench testing. This is done in the MATLAB environment for now; may move to other tools in future.
- Generate professional validation reports and comparative performance analysis of the read channel devices.
- Work with DSP and design teams to find the best optimization procedures for Marvell read channel products.
- Make sure we can showcase the best read channel performance on customer drives.
更多Marvell招聘职位:
http://marvell.cnstaff.com/
If you are interested in exploring a job opportunity with Marvell
please send me a copy of your resume to: al-china-hr@marvell.com
Email Subject: 姓名_学历_学校_工作年限_应聘岗位_意向城市; 比如: 张三_硕士_东南大学_3yrs_Platform_南京
更多关注:
Marvell官方微博:
http://e.weibo.com/marvellcn
Marvellhr官方微博:
http://weibo.com/marvellhr
发表于 2013-8-28 10:06:51 | 显示全部楼层
有没有北京的验证职位?
 楼主| 发表于 2013-8-29 15:03:54 | 显示全部楼层
回复 2# 飞扬紫百合
    北京有Verification相关职位,具体职位请见http://marvell.cnstaff.com。
 楼主| 发表于 2013-8-29 15:04:56 | 显示全部楼层
持续招募中,欢迎投递简历至 al-china-hr@marvell.com
GMT+8, 2025-12-24 00:30 , Processed in 0.019587 second(s), 5 queries , Gzip On, Redis On.
