查看: 6026|回复: 0
[讨论] 状态机问题
发表于 2013-8-18 16:07:36 | 显示全部楼层 |阅读模式
1.源代码如下不能生成状态转移图module fsm(
clk,
reset,
A,
K1,
K2,
state
input clk,reset,A;
output K1,K2;
//output[1:0] state;
reg K1,K2;
reg [1:0] state;
parameter  Idle = 2'b00,
   Start= 2'b01,
   Stop = 2'b10,
   Clear= 2'b11;
always @(posedge clk)
begin
   if(!reset)
   begin
      state<=Idle;
      K2<=0;
      K1<=0;
   end
   else
   begin
      case(state)
      Idle:
      begin
         if(A)
         begin
            state<=Start;
            K1<=0;
         end
         else
         begin
            state<=Idle;
            K2<=0;
            K1<=0;
         end
      end
      Start:
      begin
        if(!A)
        begin
           state<=Stop;
        end
        else
        begin
           state<=Start;
        end
      end
      Stop:
      begin
         if(A)
         begin
            state<=Clear;
            K2<=1;
         end
         else
         begin
            state<=Stop;
            K2<=0;
            K1<=0;
         end
       end
       Clear:
       begin
          if(!A)
          begin
             state<=Idle;
             K2<=0;
             K1<=1;
          end
          else
          begin
             state<=Clear;
             K2<=0;
             K1<=0;
          end
       end
       default:
       begin
          state<=Idle;
          K2<=0;
          K1<=0;
       end
   endcase
   end
end
endmodule
2.源代码如下能生成状态转移图
module fsm(
clk,
reset,
A,
K1,
K2
input clk,reset,A;
output K1,K2;
reg K1,K2;
reg [1:0] state;
   Start= 2'b01,
   Stop = 2'b10,
   Clear= 2'b11;
begin
   if(!reset)
   begin
      state<=Idle;
      K2<=0;
      K1<=0;
   end
   else
   begin
      case(state)
      Idle:
      begin
         if(A)
         begin
            state<=Start;
            K1<=0;
         end
         else
         begin
            state<=Idle;
            K2<=0;
            K1<=0;
         end
      end
      Start:
      begin
        if(!A)
        begin
           state<=Stop;
        end
        else
        begin
           state<=Start;
        end
      end
      Stop:
      begin
         if(A)
         begin
            state<=Clear;
            K2<=1;
         end
         else
         begin
            state<=Stop;
            K2<=0;
            K1<=0;
         end
       end
       Clear:
       begin
          if(!A)
          begin
             state<=Idle;
             K2<=0;
             K1<=1;
          end
          else
          begin
             state<=Clear;
             K2<=0;
             K1<=0;
          end
       end
       default:
       begin
          state<=Idle;
          K2<=0;
          K1<=0;
       end
   endcase
   end
end
endmodule
请问各位大神这是什么原因
GMT+8, 2025-12-14 13:34 , Processed in 0.014682 second(s), 5 queries , Gzip On, Redis On.
