查看: 2566|回复: 1
[求助] 声音信号到来判断程序“跑死”
发表于 2013-8-15 00:20:36 | 显示全部楼层 |阅读模式
reg a;
reg b;
reg c;
reg d;
///////abcd信号到来指示,为1表示信号到达
always @(posedge clka or negedge reset)
begin
if(!reset)
begin
a<=1'b0;
end
else
begin a<=1'b1;end
end
always @(posedge clkb or negedge reset)
begin
if(!reset)
begin
b<=1'b0;
end
else
begin b<=1'b1;end
end
always @(posedge clkc or negedge reset)
begin
if(!reset)
begin
c<=1'b0;
end
else
begin c<=1'b1;end
end
always @(posedge clkd or negedge reset)
begin
if(!reset)
begin
d<=1'b0;
end
else
begin d<=1'b1;end
end
//判断四路信号输入,加复位后出现以下问题
Info: Registers with preset signals will power-up high
Info: DEV_CLRn pin will set, and not reset, register with preset signal due to NOT Gate Push-Back
Warning: Output pins are stuck at VCC or GND
Warning (13410): Pin "LCD_RW" is stuck at GND
程序跑到上面提示后跑不下去了,但是把复位去掉只有
begin
d<=1'b1;
end时却可以跑,请问有何问题?
发表于 2013-8-15 15:17:31 | 显示全部楼层
negedge reset,也就是采用低复位,后面代码也是低复位。
把reset的产生逻辑发出来一下。
GMT+8, 2025-12-19 06:29 , Processed in 0.021221 second(s), 6 queries , Gzip On, Redis On.
