查看: 3639|回复: 3
[求助] Cadence assura RCX参数提取错误
发表于 2013-8-13 14:23:30 | 显示全部楼层 |阅读模式
版图模块DRC LVS都过了,在RCX参数提取时failed。查看.log文件提示“pax16”相关错误:
*ERROR* FAILED ASSERTION at "pax16": no paxnet[1]
                                           Check the p2lvs file, which may have overlapping
                                           (including abutment) lvs layers that are mapped
                                           to the same process layer.
                                           Correct the LVS rule deck, or set the environment
                                           ariable QRC_AUTO_SUBSTRATE_RESOLUTION=Y to activate
                                           automatic substrate layer short resolution.
p2lvs file 我没看出有什么overlapping layer,参数QRC_AUTO_SUBSTRATE_RESOLUTION=Y也不清楚怎么设置。
求教各位大神帮我诊断诊断~
 楼主| 发表于 2013-8-14 11:53:19 | 显示全部楼层
自己顶下,paxnet是什么啊?
发表于 2013-8-14 23:59:00 | 显示全部楼层
thanx man
 楼主| 发表于 2013-8-17 10:44:25 | 显示全部楼层
帖子不能沉啊。。。 等这个球流片啊!
GMT+8, 2025-12-5 12:42 , Processed in 0.015826 second(s), 7 queries , Gzip On, Redis On.
