查看: 45471|回复: 103
[资料] SIMSIDES: A Time-Domain Behavioral Simulator for SDMs in MATLAB/SIMULINK
发表于 2013-8-12 18:28:05 | 显示全部楼层 |阅读模式
SIMSIDES (SIMulink-based SIgma-DElta Simulator)
A Time-Domain Behavioral Simulator for Sigma-Delta Modulators in MATLAB/SIMULINK
Linux
SIMSIDES_Linux.ZIP (8.84 MB , 下载次数: 1058 )
Windows
SIMSIDES_Microsoft Windows.ZIP (7.54 MB , 下载次数: 1291 )
有人好奇為什麼要 download 這個 package?
如果你關注這本書: CMOS Sigma-Delta Converters: Practical Design Guide (Wiley - IEEE)
http://bbs.eetop.cn/forum-76-1.html
(Or, you already downloaded the eBook version from EEtop BBS. ...)
你就會了解 SIMSIDES 是書中介紹的 SIMULINK based time-domain simulator.
YouTube 上關於 SIMSIDES 的 tutorial (demo video):
http://www.youtube.com/watch?v=zT5XhBqysgU&feature=em-upload_owner
 楼主| 发表于 2013-8-12 18:30:19 | 显示全部楼层
Ding!
頂一下
User guide
SIMSIDES_UserGuide.pdf (2.96 MB , 下载次数: 671 )
List of models
SIMSIDES_Examples.pdf (83.96 KB , 下载次数: 539 )
发表于 2013-8-12 18:52:44 | 显示全部楼层
果断顶之。
话说LZ安装后可以用吗?我按照说明文档做了之后,启动出现错误。
 楼主| 发表于 2013-8-12 18:58:09 | 显示全部楼层
回复 3# cj578009030
請問你使用的 Matlab Version?
網站上的 installation guide / description 如下
INSTALLATION REQUIREMENTS
The behavioral models included in SIMSIDES have been compiled and  tested in a number of operating systems, including Mac OS X, UNIX (Solaris),  Linux, and Microsoft Windows. Both 32-bit and 64-bit system platforms have been  successfully tested in the majority of them.
Although SIMSIDES was originally developed using MATLAB© 6.5 and SIMULINK© 5, the toolbox has been updated and successfully used in  a number of MATLAB/SIMULINK versions in the last years.
NOTE(1) for Linux/Mac users: some icons and diagrams of SIMSIDES may not be properly displayed in some versions of MATLAB installed in Linux and Mac OS X operating systems.
        In order to fix this problem, just type the following in the MATLAB command window:
set_param(0,'CharacterEncoding', 'windows-1252')
NOTE(2) for MATLAB users with versions beyond 2011b. Some bug issues have been detected in the SIMSIDES Graphical User Interface (GUI) for MATLAB versions beyond 2011b. Note that SIMSIDES has been tested only for MATLAB versions up to 2011a. The toolbox and all behavioral models are fully operative for versions beyond 2011b except for the mentioned GUI bug issues. Nevertheless, in order to fix these GUI issues, follows these steps:
1)
Go to SIMSIDES/gui folder in your local installation of SIMSIDES
2) Open and edit a file named lbox2.m
3) Change the following line:
[path,name,ext,ver] = fileparts(filename);
by the following line:
[path,name,ext] = fileparts(filename);
4) Save the changes in lbox2.m
发表于 2013-8-12 19:10:13 | 显示全部楼层
回复 4# fhchen2002
我的是Windows XP系统,MATLAB的版本为MATLAB 7.0……
照他的说法,直到MATLAB2011b都可以的啊,我的怎么启动错误啊?
LZ你是什么版本?可以用吗?
 楼主| 发表于 2013-8-12 19:13:39 | 显示全部楼层
回复 5# cj578009030
按照原文翻譯
Matlab version 2011a & before 不會有問題
Matlab 2011b 是會有問題的
但有解決的方法
如下所示
1)
Hope my explanation helps!
My Matlab version is R2010b (not R2011b), at home.
 楼主| 发表于 2013-8-13 07:17:13 | 显示全部楼层
回复 6# fhchen2002
有図有真相
Bringing up SIMSIDES in MATLAB
发表于 2013-8-13 07:55:18 | 显示全部楼层
回复 7# fhchen2002
嗯,我试了一下,MATLAB2010a也可以,但是MATLAB7.0不行,只有安装个高级点的版本了
发表于 2013-8-13 08:33:34 | 显示全部楼层
回复 1# fhchen2002
    matlab安装时需要选哪些toolbox来支持吗?我2010b只安装了matlab+simulink之后,SC模块打不开
 楼主| 发表于 2013-8-13 08:47:22 | 显示全部楼层
Sorry, 我不知道需要那些 additional toolboxes (to support SIMSIDES)
我的R2010b 是 typical installation (32-bit version), and it looks OK.
GMT+8, 2025-12-19 00:33 , Processed in 0.027978 second(s), 6 queries , Gzip On, Redis On.
