查看: 3818|回复: 0
epm7128的问题????
发表于 2007-2-5 20:54:31 | 显示全部楼层 |阅读模式
大家好!
       在我使用7128时,发现有两个引脚90-OE1和92-OE2的用法不太明白;手册上说All I/O pins have a tri-state
buffer that is individually controlled by one of the global output enable
signals or directly connected to ground or VCC.好像是这两个接地或接高都可以开通三态,但是后面又说When the tri-state buffer control is connected to ground, the output is tri-stated (high impedance) and the I/O pin can be used as a dedicated
input. When the tri-state buffer control is connected to VCC, the output is enabled.我就迷糊啦当接地时,管脚可以作输入,难道不可以作输出??接高就不可以做输入啦吗??我在电路中接地啦,各个管脚都可以双向的,我不明白的是这个三态什末意思在这有何用???
GMT+8, 2025-12-29 10:37 , Processed in 0.016964 second(s), 6 queries , Gzip On, Redis On.
