查看: 5346|回复: 1
[求助] FPGA VGA显示问题。。。。。。
发表于 2013-7-16 23:47:42 | 显示全部楼层 |阅读模式
我的程序下进去后街上VGA接口,显示器没有任何反应。。。
我的显示器是三星的LED 显示器,是不是显示器的问题???但是我的显示器打CF游戏时有VGA显示的啊、、、
代码是21EDA的代码。。。应该没问题的。。。。各位大哥大姐  帮帮忙。。。。
代码如下:
--www.21eda.com
--深圳市21EDA电子
--学习LCD VGA显示原理
--在LCD上面显示 21EDA-电子
--视频教程适合我们21EDA电子的所有学习板
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity VGA_Module is
    Port ( clk50_in : in std_logic;
           Red_out : out std_logic;
           Green_out : out std_logic;
           Blue_out : out std_logic;
           hs_out : out std_logic;
           vs_out : out std_logic);
end VGA_Module;
architecture Behavioral of VGA_Module is
  signal Clk25     : std_logic;
  signal Horizontal_Counter : std_logic_vector (9 downto 0);
  signal Vertical_Counter  : std_logic_vector (9 downto 0);
begin
--Generate 25Mhz Clock
process (clk50_in)
begin
if clk50_in'event and clk50_in='1' then
   if (Clk25 = '0')then
     Clk25 <= '1' after 2 ns;
   else
     Clk25 <= '0' after 2 ns;
  end if;
end if;
end process;
process (Clk25)
TYPE Screen_Line1 is ARRAY(0 to 15, 0 to 99) OF std_logic;
CONSTANT char_L1 : Screen_Line1 :=(
--///////////////Line 1/////////////////////////////////////////
('0','1','1','1','1','1','1','1','1','1','1','0',
'0','0','0','0','0','0','1','0','0','0','0','0',
'0','1','1','1','1','1','1','1','1','1','0','0',
'0','1','1','1','1','1','0','0','0','0','0','0',
'0','0','0','0','0','1','1','0','0','0','0','0',
'0','0','0','0','0','0','0','0',
'0','0','0','0','0','0','1','0','0','0','0','0','0','0','0','0',
'0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0'),
--////////////////Line 2////////////////////////////////////////////
('1','0','0','0','0','0','0','0','0','0','1','0',
'0','1','0','0','0','0','0','0','0','0','0','0',
'0','0','1','0','0','0','1','0','0','0','0','0',
'0','0','0','0','1','0','0','1','0','0','0','0',
'0','0','1','1','1','1','1','1','1','1','1','1','0','0','0','0'),
--////////////////Line 3 ///////////////////////////////////////////////
('0','0','0','0','0','0','0','0','0','0','1','0',
'0','0','1','0','0','0','0','1','0','0','0','0',
'0','0','0','1','0','0','0','0','1','0','0','0',
'0','0','0','0','0','0','1','0','0','0','0','1','0','0','0','0',
'0','0','0','0','0','0','0','0','0','0','0','1','0','0','0','0'),
--////////////////Line 4////////////////////////////////////////////
'0','0','1','0','0','0','0','0','1','0','0','0',
'0','0','1','0','0','0','0','0','0','1','0','0',
'0','1','1','1','1','1','1','1','1','1','1','1','1','0','0','0',
'0','0','0','0','0','0','0','0','0','0','1','0','0','0','0','0'),
--////////////////Line 5/////////////////////////////////////////
'0','1','0','0','0','0','0','0','0','0','1','0',
'0','1','0','0','0','0','1','0','0','0','0','1','0','0','0','0',
'0','0','0','0','0','0','0','0','0','1','0','0','0','0','0','0'),
--////////////////Line 6//////////////////////////////////////////
'0','0','1','0','0','0','0','0','0','0','1','0',
'0','0','0','0','0','0','0','1','1','0','0','0','0','0','0','0'),
--///////////////Line 7//////////////////////////////////////////////
'0','1','1','1','1','1','1','1','1','1','1','1','0','0','0','0',
'0','0','0','0','0','0','0','1','0','0','0','0','0','1','0','0'),
--/////////////Line 8/////////////////////////////////////////////
  '0','1','1','1','1','1','1','0',
'1','1','1','1','1','1','1','1','1','1','1','1','1','1','1','0'),
--////////////////Line 9/////////////////////////////////////////
('0','1','0','0','0','0','0','0','0','0','0','0',
'0','0','0','0','0','0','0','1','0','0','0','0','0','0','0','0'),
--/////////////////Line 10///////////////////////////////////////
--//////////////////Line 11////////////////////////////////////////////
--//////////////////Line 12///////////////////////////////////////
--///////////////////Line 13//////////////////////////////////////
'0','0','0','0','0','0','1','0','0','0','0','0','0','1','0','0',
--////////////////////Line 14/////////////////////////////////////
--////////////////////Line 15///////////////////////////////////////
('0','1','0','0','0','0','0','0','0','0','1','0',
'0','0','0','0','0','0','0','1','1','1','1','1','1','1','0','0',
'0','0','0','0','0','1','0','1','0','0','0','0','0','0','0','0'),
--/////////////////////Line 16////////////////////////////////////
('1','1','1','1','1','1','1','1','1','1','1','0',
'0','0','1','1','1','1','1','1','1','1','0','0',
'0','0','0','0','0','0','0','0','0','0','0','0','0','0','0','0',
'0','0','0','0','0','0','1','0','0','0','0','0','0','0','0','0')
variable Line:integer:=0;
variable Pixel:integer:=0;
begin       --initial the screen
  if Clk25'event and Clk25 = '1' then
   if (Horizontal_Counter >= "0010010000" ) -- 144   why from 144?
   and (Horizontal_Counter < "1100010000" ) -- 784   640+100
   and (Vertical_Counter >= "0000100111" ) -- 39     why from 39?
      and (Vertical_Counter < "1000000111" ) -- 519     480+39
   then
    Red_out <= '0';
    Green_out <= '0';
    Blue_out <='0';
    -----Line 1
      -- if (Horizontal_Counter >=  "0110111000" )--440    640/2-24+144
      if (Horizontal_Counter >=  "0110111000" )--440    640/2-24+144 x
    --  and (Horizontal_Counter <= "0111101000")-- 488    640/2+24+144
    and (Horizontal_Counter <= "1000011100")-- 488    640/2+24+144
      and (Vertical_Counter >= "0011101000") --232      240-8   y
      and (Vertical_Counter <= "0011110111") then -- 247  240+8-1
       if(Pixel <= 99) then --Line 1 Lets make our Text WHITE
         Red_out <= char_L1(Line, Pixel);
       Green_out <= char_L1(Line, Pixel);
       Blue_out <= char_L1(Line, Pixel);
       Pixel:= Pixel+1;
       elsif(Pixel >= 99) then  -- All else BLACK
        Red_out <= '0';
      Green_out <= '0';
      Blue_out <= '0';
       end if;
     end if;
     end if;
   if (Horizontal_Counter > "0000000000" )
        and (Horizontal_Counter < "0001100001" ) -- 96+1   generate the hs_out and the vs_out
       then
       hs_out <= '0';
       else
           hs_out <= '1';
      end if;
   if (Vertical_Counter > "0000000000" )
        and (Vertical_Counter < "0000000011" ) -- 2+1
       then
         vs_out <= '0';
       else
         vs_out <= '1';
      end if;
   Horizontal_Counter <= Horizontal_Counter+"0000000001";
      if (Horizontal_Counter="1100100000") then    --800? decide the frequency of Hs 50000000/2/800 = 31.25K Hz
        Vertical_Counter <= Vertical_Counter+"0000000001";
        Horizontal_Counter <= "0000000000";
    Pixel:= 0;
    if (Vertical_Counter >= "0011101000") -- First Line  232
       and (Vertical_Counter <= "0011110111") then     --247
      if (Line <= 31) then
        Line:= Line+1;
      elsif (Line >= 32) then
        Line:= 0;
      end if;
     end if;
      end if;
      if (Vertical_Counter="1000001001") then  --521?  decide the frequency of Hs 50000000/2/800/521 = 59.98 Hz
        Vertical_Counter <= "0000000000";
    Line:= 0;
      end if;
    end if;
end process;
end Behavioral;
发表于 2013-8-22 12:01:05 | 显示全部楼层
process (clk50_in)
begin
   else
  end if;
end if;
end process;
可以综合吗?
GMT+8, 2025-9-20 13:07 , Processed in 0.018737 second(s), 6 queries , Gzip On, Redis On.
